How do I dull down paint per NCRS ?
Old 10-22-2012, 11:02 PM
bshaw1
bshaw1's Avatar
Default How do I dull down paint per NCRS ?
I have the usual base coat clear coat paint on my 67 Corvette
NCRS and BLOOMINGTON will take away all of your paint points if your
door jams, inside hood, front and rear valance panels are too shiny
The rationale is that the factory did not buff these areas originally
HOW DO I DULL the areas? I heard that there was a spray flat or semi clear that woulld work on the areas without sanding and that the paint would stick and not peel up
Any help would be appreciated!
Bruce Shaw
Old 10-23-2012, 07:13 AM
Hitch
Hitch's Avatar
I have seen and heard that hair spray will create the correct sheen..
David
Old 10-23-2012, 07:43 AM
VetteJohn
VetteJohn's Avatar
Default Rubbing Compound
I read in one of the Corvette mags that one guy used rubbing compound to dull down the jams in order to get max points. He ended up getting no deductions for paint.
Old 10-23-2012, 09:08 AM
csherman
csherman's Avatar
Received 1,434 Likes on 738 Posts
C1 of Year Finalist (stock) 2019
2018 C1 of Year Finalist
clear coat with flattener added
some guys use a matte spray bomb
hair spray does not look right and judges are now looking for it....
Old 10-23-2012, 09:46 AM
Vette Daddy
Vette Daddy's Avatar
Satin clear with the tape edge rolled back while doing the jambs and other areas.
Old 10-23-2012, 10:19 AM
66L72
Support Corvetteforum!
66L72's Avatar
exactly.
my car got full points for paint using this method
Old 10-23-2012, 10:30 AM
Geralds57
Geralds57's Avatar
2023 C1 of the Year Finalist - Modified
2022 C1 of the Year Finalist - Modified
2020 C1 of the Year Finalist - Modified
2019 C1 of Year Finalist (performance mods)
The matte finish spray works very well. Artist shops and hobby lobby stores have it too. Start with a light coat and then add to it if a flatter finish is desired.
To How do I dull down paint per NCRS ?
Quick Reply: How do I dull down paint per NCRS ?
