Is there any difference in the frame for a coupe or a convertible??
Help please. My midstyle's frame has never been good. I've found one close by, and have found enough info to confirm the year - so all that is good. BUT I found a couple sites that seemed to list a coupe frame as a different item than a convertible frame. I never thought there was a difference.
Anybody have some insight on this for me, I need to act fast to get the frame.
Thanks guys!
Thanks guys!
What year are you inquiring about? 63 frames are all the same, 64 and 65-67 convertible frames have an extra mount.
Nothing on a convertible frame, will prevent you from using it under a coupe body. When using a coupe frame under a convertible, you should add the extra mount back to the frame.
If it's a good frame at a good price - grab it. The #2 mount issue is easy to deal with.
Hi. Thanks so far. Yes, I knew about the dent for the balancer starting in '65, the recessess in the rear kickup rails for the rear sway bar as well, and the sometimes rusty famous keyhole slot in front of rear wheels to allow for the side exhaust mounting. But I don't know what or where this extra mount is for a convertible that you mention.
Can anyone tell me (preferably show me on a picture) where this extra mount is an what it does??
Here's a link to a 1964 frame picture, here on the forum:
http://forums.corvetteforum.com/c1-a...tte-frame.html
And here's a link to a 1967 corvette frame picture:
http://dynamiccorvettes.com/february-16-2011/
Can anyone sue these to show me where & what this is? A PM with a picture would be OK, or post something here. Thanks again.
Received 1,857 Likes
Photo below shows the '64-'65 frame diagram - note the mount just forward of the end of the transmission crossmember where it says "867 only" - that's the #2 mount, used only on convertibles. It was welded to the frame at St. Louis on convertibles only, and is accessed through a hole in the sill, after removing the sill plate.
I see JohnZ beat me with much better details.
Wow! Great reply
Great job. Thank you. Based on your diagram, it looks like my picture below is definately a convert frame. I guess I'll be grinding off those brackets
Interesting your diagram for 64-65 doesn't denote the differences between the frames between 64 & 65: the depression for the balancer in the front cross member, and the narrowing of the real rails for the rear sway bar arms. Do you mind telling me where you got the diagram? I really like it.
Thanks again.
Hi, Can you tell me which part is called "the birdcage?" I have been asked to look to report the condition on a 64 I have for sale on the forum and would like to know if I will be able to give an honest look....after I figure out where it is. Thank you.
The birdcage
Here's another post for your reference.
http://forums.corvetteforum.com/c3-g...-birdcage.html
Please don't turn this thread into a birdcage thread. I'd like to hear back from the 2 great guys that helped me out (above), and find out where that great diagram came from. I'd really like to buy them both a burger and a beer .... but we live a fair ways apart
I really appreciate that information. Will do the best I can to check the areas you mentioned. I didn't figure it would be like you described. No wonder the car rides so solidly. I guess since it was garage kept for over 40 years that should help.Thanks again. This forum.......is great!
A quick gander at the design tells me they were added to make up for lack of an over the top birdcage on a convertible, to combat excessive body flex on a convertible, and would just give added strength to a coupe body.
Doug
Thanks again.
Thanks again.
I have a 64 coupe, I fabbed up those brackets and welded them to my frame. The bird cage already has provisions for that mount under the sill plate. The 64 coupes get a bad rap. They have 10 mounting points. Everyboby forgets about the two body mounts at the rear of the driveshaft tunnel. Those vert brackets will give you twelve mounting points.
Sorry, but what is up with the later Big block C2s. They only had 8 mount points.
Unless you are going NCRS, and if those brackets would deduct NCRS points, I would suggest leaving them if they do not interfere with a coupe body.
Doug
Doug
Thanks again.
Thanks again.
The indentations in the '65-up rear rails are for caliper clearance at full rear suspension jounce.
Leave the brackets on the frame and use them for body mounts - it'll add some torsional stiffness to the coupe.
You'll find that diagram in Section 2 of both the '64 and '65 Corvette Shop Manuals. It's for frame gaging dimensional references, so it doesn't show details that are unrelated to frame measuring/pulling dimensions.
I have to agree with JohnZ about the side indents on the frame. They are for caliper clearance. You may be thinking about the notch on the crossmember gusset.
Here is a picture of the birdcage
One day when you have nothing to do - try to fit a 9/16" sway bar around a 63 or 64 rear frame rails. Guess what ... the arms are too narrow and it will never fit. The eyebolts have no room to travel. You can save a bunch of time just using a tape measure, or just look at a big block car's rear bar & frame to see the situation, and how close the bar & bolts run to the indented frame.
Then I will send you a picture of a very nice 63 SWC doing autocross that's been running disks for 20 years with no frame mods (No rear sway bar though), and it's low and got lots of negative rear camper so you know the caliper is pointing it at the top toward the frame - no issues.
Either way, no mater who is right, I think this forum is great, and we're talking about fine issues on cars that we all seem to be fortunate enough to enjoy and know a little bit about them. Thanks for the info & discussion guys.
Well ..... OK.... or not . When you're run into the issues yourself and hauled out the grinders and welders to fix them, you sort of know when you're cutting a frame rail and when you're cutting a crossmember.
The second photo shows the (stock) notch I mentioned in the crossmember gusset that appears to be there to possibly allow clearance for the sway bar on BB cars. I'm not positive on this point, but why else would it be there?
