Gas/Petrol Fumes
Gas/Petrol Fumes
I have heard this from another 1960 corvette owner and it prompted me to write a post.
If I fill up my 1961 Vette to the top, I can smell fuel fumes for quite a while while driving.
If I fill it 3/4 or 1/2, no probs.
After the first time I actually pulled over and checked the carbies and fuel line.The second time it happend was this weekend and I clicked it is only when I fill it to the top.
The filling cap is of course on the panel right next to drivers side on the left. Fuel will be moving back and forth in the tank.
I notice fuel is sometimes at the bottom of the fuek tank filling point when I go to fill up, like its split but the cap is tight.
The fuel caps are a breathing set up, but why am I getting such fumes when full?
Why is it leaking out as when I check the fuel cap its tight?
Lastly, there is a small rubber open hose above the fuel cap. I suspect its a breather, but whats it for exactly?
Would the fuel cap need replacing or do I need to lift the soft top and get access to the fuel tank and make some mods?
St. Jude Donor '07
the C1 uses a non-vented cap and the hose is the vent line for the tank.
if you fill the tank to the top, the gasoline will expand and overflow out the vent line.
solution, don't fill the tank to the top.
Bill
Bill
If you top off the tank completely you can actually make raw gas run out the long rubber vent tube that goes to the filler gas cap cavity. I can produce the gas smell on demand by making hard right turns (particularly uphill) with a brimming tank. It's normal but avoidable if you don't top off the tank.
Received 1,857 Likes
Read this - it shows all the causes, and the fixes.
http://www.lbfun.com/warehouse/tech_...hnHinckley.pdf
Great Help again guys.
Please forgive me for my knowledge on the light side on C1's.
I have had Mustangs all of my life. This is my first Chevy buy.
The article was spot on and.... I have a vented fuel cap - Will get this changed right away.
Kind Regards,
John
Kind Regards,
John
St. Jude Donor '07
Bill
I am "learning" the car at the moment.
Not to hijack this thread, but where can you buy non vented caps. I have one of the very expensive Stant reproductions that I will use for judging, etc. But I don't want to leave it on the car. The only ones that Paragon or Corvette Central advertise for my 1960 are vented.
Don
Don
Don
Don
St. Jude Donor '07
the Autozone site shows that 10810 part # (actually the CST 6810) as a vented cap...
http://www.autozone.com/autozone/par...fier=4367_0_0_
Stant shows it to look like this
http://www.stant.com/modules/partLoc...m.cfm?id=10810
Bill
Jeff
Bill
Bill
St. Jude Donor '07
http://shop.advanceautoparts.com/web...archTerm=10810
definitely wrong...
Bill
NAPA #703-1205 cap works great on C1s.
Received 4,583 Likes
C1 of Year Finalist (appearance mods) 2019
Does anyone have pics of the grommet and drain hose that goes under the body, mine is missing.
I learned many years ago not to fill my 62 completely by the way.
Wow - neither can I ! NAPA must not have had enough demand to continue carrying it...it isn't even listed on the STANT (the OEM cap manufacturer) web site any more.
Go with the STANT 10810 per the John Hinkley article and that is listed as a direct replacement for the #703-1205 cap...should work perfectly.
UPDATE:
Well now it looks like the STANT 11810 replaces the 10810...my head is starting to hurt.
NAPA #703-1684.
When you use STANT's online vehicle selection search it says 10640 gas cap. This last one has the label on it about venting and anti-surge; so I would NOT use the 10640.
You want NON-vented cap!
UPDATE:
NAPA #703-1684.
UPDATE:
NAPA #703-1684. When you use STANT's online vehicle selection search it says 10640 gas cap.
I am NO EXPERT but I suspect the difference is indicated by the red arrows as well as the warning label.
First pic is the 10640 - vented; second is the 11810 NON-vented.
UPDATE:
Their computer showed another one compatable with the 1960, part number 703-1033 and it is also vented.
If you look on Stant's web site and search for the 11810, it comes up as part number 10810, which also is cross referenced as NAPA 703-1684, which is Vented - My head is spinning also.
I just sent an Email to Stant to see if they make a Non-vented cap for the 1960 corvette. Paragon has one listed for 57-58 (equal to GM part number 3751027) which I assume should be Non-vented and that GM number is listed in my 1960 AIM as one of three gas cap part numbers, so it should work for my 60. Their price for this cap is $37 and I spent all of $5 for the Vented one I bought at NAPA.
I'm going to send an Email to Paragon to see if they can tell me if that one is Non-Vented.
I also emailed STANT asking them about non-vented caps for C1 Corvettes - let you know what they come back with (if they do!).
I haven't looked at all the vendor's gas caps for C1s - but the 2-3 that I HAVE looked at were ALL wrong and VENTED....which is why I wound up at NAPA in the first place a few years back.
Paragon's shows "ANTI-SURGE" and "VENTED" right on it. It is WRONG.
St. Jude Donor '07
How did you determine that ?
if you look at my links, every site i looked at showed the 703-1205 as a picture of a vented cap of some sort
Bill
After diddling in cyberspace I am becoming convinced that this STANT cap may be "The One"! (it is listed as "sealed") -
