three deuce set up???
Old 11-10-2012, 04:35 PM
Kerrmudgeon
Kerrmudgeon's Avatar
Received 4,583 Likes on 2,157 Posts
C1 of Year Finalist (appearance mods) 2019
Default three deuce set up???
Perfect Offenhauser manifold with 3 Rochesters, 2 never filled with fuel. What's it worth??
I'm thinking of a cool nostalgia system for my 56 Belair, and this is available locally.
Old 11-10-2012, 05:22 PM
toms silver 60
toms silver 60's Avatar
Go to Charlie Price Vintage Speed web site, he has a number of "new" setups from $1200 to more than twice that depending upon bells and whistles. The site also gives prices for rebuilt carbs, linkage, lines, etc. Be sure to add core charges in there, they can add up. Also, the end carbs are different critters than the center carb if you want it to run correctly.
This should give you an idea of what the setups and components cost new. You can find beater sets all up and down the range from $250? up but the carbs could be trash. Good news is you don't have a hood clearance issue with a Bel Air.
Tri power is the way to go!
Old 11-10-2012, 05:29 PM
Sky65
Support Corvetteforum!
Sky65's Avatar
St. Jude Donor '05, '09, '15
I'm running three deuces on SB 65. I like the setup. Runs on the center carb until you stomp it. Fuel economy seems better but I never checked it. Throttle response is great.
As far as worth I agree. Prices are all over the place. I've seen many for sale that are not set up properly and I'm sure ran like crap. I built my set up. Post some details.
Tom
Old 11-10-2012, 05:50 PM
Kerrmudgeon
I was thinking of a 2X4 setup, and I have one of those, but this set up is CLEAN, and cheap, like 200$. Running on 2 barrels and having 4 kick in when you stomp it seems more sensible than a front 4bl carb sitting doing nothing most of the time, and four kicking in is not as rich as 6 so it may run actually better. I know guys who drag raced in the old days and this was the preferred setup, but they had to make the hood fit on C1s.
Old 11-10-2012, 06:14 PM
Chicago Pete
Chicago Pete's Avatar
Tri-Powers are fun!
Go for it.
Old 11-10-2012, 06:18 PM
toms silver 60
Go for it, just the end carbs if rebuilt properly are worth much more than that....
Check out that web site, they have all kinds of parts if you need any.
Old 11-10-2012, 07:29 PM
wmf62
wmf62's Avatar
St. Jude Donor '07
Tom
check the fuel lines...
Bill
Old 11-10-2012, 08:28 PM
Kerrmudgeon
thanks for the input guys, great pics BTW.
At that price, I could even use it as garage art!
Old 11-10-2012, 09:57 PM
Sky65
Sky65's Avatar
The manifolds are over $200 new. If that is in good shape I would do it. If the carbs are not set up right you can fix that.
Tom
To three deuce set up???
Quick Reply: three deuce set up???
