Finished Dan C's restomod
Old 11-17-2012, 06:58 AM
mike coletta
mike coletta's Avatar
Received 1,067 Likes on 513 Posts
Default Finished Dan C's restomod
I think it might be a new record.......I removed the body from the original chassis on Aug 11. Took it for a test ride on Nov 16. I drives out really nice. Here is the old build thread http://forums.corvetteforum.com/c1-a...ct-update.html
Mike Coletta
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG][IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Old 11-17-2012, 07:12 AM
midyearvette
Support Corvetteforum!
midyearvette's Avatar
youre' the best mike!
great job, as usual........
Old 11-17-2012, 07:15 AM
Frankie the Fink
Frankie the Fink's Avatar
Received 7,082 Likes on 4,736 Posts
Army
Another amazing job Mike. Been meaning to get by to see this but my consulting biz went a little crazy around election time.
I know you had to deal with some challenges on this one so its nice to see it come together so beautifully !!
I don't know how many realize that Mike is a "one man show" and does it ALL and pretty darn quickly too.
Old 11-17-2012, 07:18 AM
Mike Geary
Mike Geary's Avatar
Kudos Mike! Just superb. Wish we had someone of your caliber here in the sunny Southwest. Mike
Old 11-17-2012, 07:24 AM
RatDog
RatDog's Avatar
Received 1,581 Likes on 818 Posts
St. Jude Donor '20-'21-'22-'23-'24
Wow! That's a beautiful car!
Old 11-17-2012, 08:31 AM
dcaggiani
dcaggiani's Avatar
Mike
I was at the Atlanta airport last night making my way home to West Palm when I received your email with these photographs. The Roadster is simply breathtaking. I spent the entire flight just staring at these pictures.
I know she fought you until the end but boy it was so worth it!
I am honored to have a Coletta built Restomod and cannot wait to come pick her up next weekend.
Dan
Old 11-17-2012, 08:56 AM
torose
torose's Avatar
nicely done What type of seats are those as they look like they fit well?
Old 11-17-2012, 09:04 AM
dcaggiani
dcaggiani's Avatar
Thanks! The seats are Procar Rally 1000 by Scat Enterprises. I chose them because I wanted to have comfort and head rests while keeping a somewhat heritage look. While they may not be everyone's cup of tea (including Mike perhaps), I will appreciate them after a long drive.
Dan
Old 11-17-2012, 09:46 AM
cbernhardt
cbernhardt's Avatar
C1 of Year Finalist (track prepared) 2019
Nice work mike.
You must have been breathing out of both sides of your mouth on this one!
Charles
Old 11-17-2012, 09:56 AM
stratplus
stratplus's Avatar
Mike, that is beautiful and you certainly are talented at your craft.
Old 11-17-2012, 10:37 AM
Islander21
Islander21's Avatar
Mike and Dan, is that a push button ignition? If so, can you elaborate on it?
Old 11-17-2012, 10:49 AM
SpartyGW
SpartyGW's Avatar
I watched the original build thread. It's amazing how much work was done at this high quality in such a short time frame. Amazing.
Old 11-17-2012, 10:59 AM
VeroWing
VeroWing's Avatar
Very impressive!
Old 11-17-2012, 11:10 AM
dcaggiani
dcaggiani's Avatar
Good eye! Yes that is a push button start. I was looking for a security type system for the Corvette and really did not like the options available with the annoying sirens. Then, I saw Mike's 64 with a push button start and I was sold. Just like the modern day cars, you need to have your fob on you and actually push a button on the fob to allow the push button to actually start the car. To me, it adds the security I was looking for while not having keys hanging off the dash or worse, hacked and stolen.
Check out the vendor site for more information
http://www.digitalguarddawg.com/KEYL...--PG-1temp.htm
Dan
Old 11-17-2012, 11:35 AM
LoneStarV
LoneStarV's Avatar
Nice Vette Dan. Very well done combo of the old and the new. Prolly think you're hotshit now. LOL! You are!
Old 11-17-2012, 11:42 AM
dcaggiani
dcaggiani's Avatar
No way - just humbled I have the opportunity to own and DRIVE one soon.
Can't wait to see yours come together.
Old 11-17-2012, 01:14 PM
kiwigt
kiwigt's Avatar
Mike, could you advise how you mounted the Scat ProCar seats please?
To Finished Dan C's restomod
Old 11-17-2012, 03:58 PM
bigearl56
bigearl56's Avatar
Default Fine work indeed!
COLETTA, COLETTA, COLETTA, Man your killing me over here!
Absolutly looks great and congratulations on a job well done.
Earl
Old 11-18-2012, 06:58 AM
mike coletta
Thanks all !!!!
Regarding the push button start. Digital Guard Dawg is now making the system to comply with whatever laws govern that type of thing. With the old system, you would simply activate(unlock) the ignition via approaching the car in automatic, or pushing an unlock button on the fob. To stop the engine you would just hit the button again. There are also some ways to get to acc mode, etc. This is what I have in my car. The NEW system, which is in Dan's car, works entirely different (personally, I don't like it). You still approach the car (in automatic mode), or push the unlock button on the fob, but in addition, you MUST have the brake depressed. So that means that there is no reaching over the side, and starting the car. The thing that I don't like about it is the off procedure. You MUST have the brake depressed, and you HOLD the ignition button for 3 seconds. So, in a panic, you must hold the brake, and hold the button. If you don't do those things, it will keep running. I called the manufacturer, and asked if there was any way to bypass this, and was told that there is now legislation/laws that require this shutoff procedure. Something about a kid hitting the stop button in a Toyota going down the freeway in Calif, and causing a major wreck. You can bypass the brake switch requirement for start and stop, but then you have to give up your Acc position. Sorry to ramble.......I still don't like it.
The seats are very tight. I just drilled some holes, and bolted them in. I cut as much of the mounting ears off as I could, to get them as low as possible. The "sitting" portion of the seat ends up just a little higher than stock, but the side bolsters are huge, and would require either a tilt wheel, or a diet program, to get in the car without too much effort. I also had to modify the seat belt mounts, to extend them upward on the inboard side. I THINK that stock belts (or similar), would probably work without modification.
Thanks again to all of you for your comments!!!! I'm sure that Dan and his family are going to have a blast with this car.
Mike Coletta
Old 11-18-2012, 08:15 AM
Islander21
Islander21's Avatar
Originally Posted by mike coletta
Thanks all !!!!
Mike Coletta
Mike, which kit did use use for the push-button ignition? the 19mm, std 22mm or the 25mm?
Quick Reply: Finished Dan C's restomod
