What 1956 Single 4Barrel Manifold # Goes With 306 Heads
I'm trying to build a '56 265 Vette spec. engine. I have a 3720991 block, access to 3725306 heads, but am unsure which of the '56 four barrel manifolds matches up to these heads. There are several listed in the info I found online. These include:
3737109
3735448
3837109
Does anyone make a camshaft for the 210HP 265? Was it a mechanical lifter type or hydraulic?
Thanks in advance for your help! I'm a newbie...
Bill
3737109
3735448
3837109
Bill
Received 1,857 Likes
3737109
3735448
3837109
Bill
3737109
3735448
3837109
Bill
Nobody reproduces the original '56 #3711354 solid-lifter camshaft as far as I know, although others may have a source for it. '55 and '56 were the only two years where the base engine used a solid-lifter cam - from '57-up, the base engine cam was always hydraulic. All '55-'56 cams also had a flat machined on the rear cam journal (the flat on the hydraulic cam was larger than the flat on the solid-lifter cam) to feed oil to the lifter galleries, and they used a special 2-hole rear cam bearing.
That cam had slightly more lift and about 35* less advertised duration than the "097" Duntov cam. Any small-block cam will work as long as the rear journal is machined with the flat.
Received 1,283 Likes
John;
Correct me if I have this wrong...but you can also connect the two holes in the rear cam bearing (an oval shape), or machine a small slot in the rear of the block so that the flat on the cam is not needed.
The flat on the cam allows oil to flow from one hole in the cam bearing to another. connecting the two holes in the bearing together into one oval hole, or notching the block is an alternative.
John;
Judging probably isn't in his plan, but if it is, the real issue will be coming up with a cam that has solid lifters (for the expected mechanical sound) and has base cam idle smoothness. Otherwise, the good old "929" base hydraulic cam will work fine (with a flat on it or with the rework to the rear bearing or bearing bore).
