One piece front end grill opening removal of tabs
Have battled through all of the fitting and aligning of an ACI door to door front end, all is OK. I have a question on trimming the tabs off in the grill opening.
Do I cut the tabs off and clean up the edge or is there a measurement from the front edge that I need to follow? If there is a measurement I will need both the top and bottom measurements.
Appreciate any and all help.
Yes it is a 66. So leave the middle upper and middle lower since they are flat?
Leave the whole tab on the upper. The center support bracket (if it has one) and the grille bolt into the vertical part of the tab. The lower center tab is flat, but sticks out. If you set the grille in the hole, you will see.
