15 X7 rally wheel variations?
Old 11-27-2012, 08:09 AM
Fawndeuce
Fawndeuce's Avatar
Default 15 X7 rally wheel variations?
Hi,
How many variations are there of the 15 X 7 rally wheel? I did a search and couldn't find, is there a list anywhere with the codes and back spacings?
A friend with a '67 found a set supposedly from an early Monte, he asked me if they would fit his car.
Thanks,
Paul
Old 11-27-2012, 12:06 PM
Larry N. Johnson
Larry N. Johnson's Avatar
Default Ralley Wheels
There is complete info at Ralley Wheels
Old 11-27-2012, 12:37 PM
JohnZ
Support Corvetteforum!
JohnZ's Avatar
Received 1,857 Likes on 1,100 Posts
Originally Posted by Fawndeuce
Hi,
Thanks,
Paul
I'm only aware of two 15 x 7 OEM rally wheels:
"YH" or "FW", +0.30" offset, originally GM #3997899, used on '69 Camaro Z/28 and on '69 Camaros with JL8 4-wheel discs, and '70-'72 Monte Carlo (also used on some disc brake station wagons). This wheel will move the inboard rim flange inboard another 3/4", and will move the outboard rim flange outboard another 1/4" vs. the stock 15 x 6 rim.
"AG", -0.28" offset, originally GM #3910799, used on '68 Corvette. This wheel will move the inboard rim flange inboard another 1/4", and will move the outboard rim flange outboard another 3/4" vs. the stock 15 x 6 rim.
Old 11-27-2012, 01:32 PM
66since71
66since71's Avatar
Just a caution; The Camaro/Monte Carlo wheel will interfere with parking brake cable bracket and possibly the spring end in the rear. It should work fine in the front however.
Harry
Old 11-27-2012, 01:49 PM
Kerrmudgeon
Kerrmudgeon's Avatar
Received 4,583 Likes on 2,157 Posts
C1 of Year Finalist (appearance mods) 2019
Thanks for that John. Do you have the difference in offsets for the early cars as well (5 in.)? I know mine just clear in the front.
Old 11-27-2012, 01:55 PM
Fawndeuce
Fawndeuce's Avatar
Thanks for the great info guys, I'll relay it back to my buddy.
Paul
Old 11-27-2012, 01:58 PM
JohnZ
JohnZ's Avatar
C1 5" rims have +0.56" offset; RPO 276 5-1/2" rims have +0.44" offset.
To 15 X7 rally wheel variations?
Quick Reply: 15 X7 rally wheel variations?
