C1 fuse points
Two underdash shots. First is just the 30 amp ammeter fuse (green item in holder).
The second pic is BOTH fuses; the 10 amp cigarette lighter fuse (red in holder) in the upper left - again the 30 amp green fuse is in lower right. Note the shrinkable insulation on the lead coming out of the cigarette lighter -- muy importante.
I eliminated the clock fuse once I went quartz. No original wiring was harmed in the installation of these fuses.
I DO put my money where my mouth is.
Might also want to take note of the nice white wiring labels from a Radio Shack wire labeling kit. Just stick a corresponding label on the back of the dash/component where that wire should go and then keep a written legend. E.g. Wire #12 is bulb for Hi-Beam Indicaior, etc..
Removing/replacing the dash cluster is a breeze with these puppies.
A fusible link will stand temporary high-current situations without blowing - which might occur when say starting the car, or putting on high beams. Most fuses (even many slo-blo fuses) will just blow straight away in an overload situation. This is why GM started using the links in later years in particular circuits.
In some extreme cases a high current can arc through the metal vapor even when a fuse blows and still cause damage -- a fusible link breaks the circuit for good. Admittedly rare but not impossible.
Ktholin (02-13-2020)
That is very true.
I meant to add somewhere above that you can preserve the original black ammeter harness wire by either: a) soldering the fuse holder lead to that original harness lead ring terminal and putting a ring terminal on the other end to go on the ammeter connector (you can desolder it later and preserve the original wiring if need be, or, b) crimping a ring terminal on EACH end of the fuse holder and use a small nut & bolt to connect one end to the original harness wiring's ring terminal. This last method is a little messier IMO but will work. You have to VERY carefully insulate everything in either case. A DOUBLE layer of heat shrinkable tubing is best.
Seems many folks don't want to add this extra protection out of fear of butchering up their dash harness and that doesn't have to be the case. The clock/lighter connectors are easy and male/female spade lug connectors can be crimped onto the fuse holder leads that work perfectly for those circuits.
For a couple of hours effort on a Saturday morning you can make a C1 a much safer car to operate.
I took FTF's advice years ago and fused those circuits, but I also put in a power antenna and fused that, and converted my windshield washer to a power pump and fused that circuit. Got a lot of fuses under the dash but was greatfull when I blew the main 30 amp fuse when I was playing with the cigarette lighter. Also, I prefer fuses that light up when blown, much easier to see under the dash.
I take my profession seriously and when spotting a safety flaw (my call ) I'm compelled to see it through. I would hate to see any car, get fried or allow someone to get hurt because I didn't step in.
I'm positive that Frank was thinking he was giving his best and didn't see any safety flaw. His intentions were just, but not completely sound. This was my judgment call in providing an alternative safer method.
Be safe!
rustylugnuts
Be safe!
rustylugnuts
Read the middle of the first paragraph on this page and then just buy this tech guide from a very respected automobile electronics vendor if any of you want to know the rational for fusible links over regular fuses. It's not just me saying this:
http://www.madelectrical.com/catalog/tb-1.shtml
In nearly every post where I provide advice I include technical references, quotes from the ST-12 or pictures from the AIM, schematics, or stuff from other authoritative sources and often pictures of how I incorporated any mods into my car. I don't advise anybody to just buy a 'pig in a poke' because I say something works.
So - you pays your money and you takes your choice !!
I have that book and along with the fact that the General believed in fusible links to protect high load circuits it's made a believer out of me. I don't know what that other guy's deal is.
Thanks Frankie for doing what I could not... I suggested a awhile ago that a one stop post for fusible points would be extremely helpful and you nailed it! A smoking dash started my body of restoration over a year ago... scared the crap out of me! Thanks!
Cruising
Thanks Frank. I have a question about the black wire on the ammeter. In the '56 and I am guessing '55 and '57 there are twoo black leads off the ammeter, the one to the starter solenoid and the other goes off to form part of the negative side of circuit. Should both of these be fused (together?) or just the one to the starter solenoid?
Regards,
Craig
Regards,
Craig
Bad mouthing
I was the instructor for all Naval aircraft maintenance personal at NADC Naval Air Development Center & NAWC Naval Air Warfare Center Warminster, PA 1984 - 1994 (2000 hrs class room). Was an advisor/technician for US Air force GSE/PAO Cart for F-22 Raptor in accordance with Lockheed Martin, written procedures, in unison USAF/USN standards and regulations Graduated 3rd in my class at CHI in 1993 as Master in Electrical, and I wouldn't rely on any of it to my 32 years experience in the field.
oh and work on F-14A+ FA-18 and Corsair A6's Orion P-3's & CH53"s helicopters, So what's your point!
rustylugnuts
rustylugnuts
Why do you seem to jump on most postings and tel all what a knowledgable guy you are? Then you proceed to attack their post.
I'd like to see your solution to this problem.
Merry Christmas to all.
Roger
#33
Received 1,856 Likes
There are two black wires on that ammeter terminal - one is the main power feed from the cable stud on the starter solenoid (which should have a fuse or fusible link at the solenoid), and the other black wire goes from the ammeter to the "BAT" terminal on the ignition switch.
#34
c-1 fuse points
Good photos Frankie and advice from other members. I'm ready to install fuses and wonder if there is a source to replace some of the three and four place connectors (especially the ignition switch connector shown in Frankie's photo) I also don't like the way that I've spliced several ground wires together. Can't do 500.00 on a body harness. 59 navy
#35
Perhaps Lectric Limited or Mad Electric sell connectors separately. You will have to call to find out.
#37
A few months ago having a fused circuit saved the day for the wiring harness in my car. After installing a Pertronics 3 module in the dizzy, with everything ready to go.............turn the ignition key.................nothing happens?. No headlights, nada. Check the fuse and it's blown.
Turns out one of the two wires that goes to the Pertronics unit got pinched ever so slightly when the unit was being tightened in place; enough so to break the insulation and short the wire to ground. No doubt a significant portion of the wiring harness would have been ruined had there been no fuse protection. The ammeter, clock, and lighter all have fuse protection, also.
Instead of cutting directly into the wire circuit to be fused, all the fuse holders were installed using appropriate same style connectors (ring, male/female spade, etc.) on the wiring ends of the those fuse holders. The fuse connector section was connected to the end of the original factory wire terminal connector, then onto the terminal end of the solenoid, gauge, etc.
Fusible link or fuse, it's definitely with the time to install either form of circuit protection.
#38
Happy New Year
rustylugnuts
#39
Wish you luck, happy New Years
rustylugnuts
#40
Also for the inline fuses, do I need to use the same rules for wire gage (2 sizes smaller) that I need for the fusible link?
Thanks, Dan
