synthetic blend power steering fluid
While checking my powersteering fluid level the other day I noticed it was very low on the stick. Is it OK to use Havoline synthetic blend PS fluid in my 63?
Received 6,929 Likes
2015 C2 of Year Finalist
I would not mix it. if you have standard oil in there keep it all the same
Received 1,856 Likes
ALL power steering fluid is a "synthetic blend", and always has been - that's marketing hype. Use the current GM fluid, which is backwards-compatible and will work just fine.
