C-2 dash lights revisited
I just installed the dash on my 65. New harness, bulbs, switch etc. OMG, the dash lights are very dim. I don't remember them being that dim in any other C-2 I've owned BUT my eyes were a lot younger then. I did a search and some were happy replacing the 1816 bulbs with 1817's. The trouble is, those have been discontinued, even through Atlanta Bulb Co. that was the only place left that had them.
Has anyone come up with an alternative bulb # or other solution?
Jim
Jim
I can't help with the replacements, but I can verify that the originals are very dim. It has to be pretty dark to even take advantage of having them on.
Received 1,962 Likes
I have my dash out to fix the speedo . . . when I put it back together, I'm putting these in:
http://www.atlantalightbulbs.com/eca...ge=description
. . . direct replacement, one-third brighter!
Tom
Tom
Have you checked your ground connections?
Also, have you checked the rheostat within the headlight switch?
The dash lights in my 63 are bright.....................
Something isn't right.
Chuck
Chuck
Funny - I don't remember dash lights being that dim back then either, but both my Corvette and my 67 GTX have restored instrument panels with new bulbs and I can barely read the gages in both of them. Beats me what has changed. I guess my eyes and memory.
Jim
Received 2,126 Likes
I repainted the green interior of my cluster with a brighter green, and installed the 1817 bulbs. No problem seeing things at night.
DansYellow66, I sent you an e-mail a while back about your GTX. Did you ever get it? Dennis
The bulbs are the same brightness whether they are installed in the dash or out of the car hooked directly to a battery. That eliminates a ground and rheostat issue. Since many have posted the same problem, and we're all getting older, maybe it's just my eyes or I'm used to my C-1 which has very bright dash lights.
Jim
Jim
That's the problem, I know my dash lights look very dim, but to everone else they look bright. So, it must be my eyes, and getting older. It surely can't be my outlook on life...
Bruce
Seriously though, I decided not to worry about it. The dash is all back together and body off resto. will be finished in a week or so. Gotta find another project soon or I'll go crazy-er.
Jim
Thanks for confirming my suspicions Bruce. The picture of you in your avatar provides a clue to your problem. Are you wearing those sunglasses at night?
Jim
Jim
I just call that being normal...
Bruce
For what it's worth, mine are dim as hell and I'm a bit younger than the average in here.
A brighter bulb would be nice, but on 40+ year old wiring I'm not putting a higher draw bulb in there (and there's NO WAY IN HELL I'm bumping up fuses to do so).
Jim, is the battery you are using to test fully charged?? Maybe it's just me, but the bulbs (all new) in my 64 dash seem a tad brighter with the engine running but either way plenty bright to look at. I would also agree with you that the C-1 dash appears bighter than the C-2 (maybe due to the different bulbs). Pilot Dan
Mine are dim too, even with the headlight relay conversion.
In fact they are so dim that when I threw the belt the other night, I couldn't see the temp gauge well enough to realize it pegged. Though it was probably a bit dimmer without the belt.
Thank whomever for iron heads and synthetic oil.
Jim
Yes. #1416. They're big, but they will fit in the openings for the cluster illumination bulbs. Available at a couple of places including www.bulbster.com.
You will have to put a 10 amp fuse in, but the wiring will hold up just fine.
I agree that the dash lights are too dim and I want a much brighter bulb. I have heard that there is an LED bulb that is 3 times brighter and will fit this socket. I have been researching this, but have not found such a bulb yet. I was at the SEMA show and saw such bulbs in car dashes on display. They were very bright and came in multiple colors. Unfortunately, they did not have a Corvette dash on display. Keep in mind that an LED bulb would draw less power, so no need to change any fuses. Does anyone know of such a bulb?
Dejavet
Dejavet
Dejavet
Dejavet
charles, 66 vette
Dejavet
Dejavet
