Removing gas residue from an aluminum intake manifold
Hate to beat a dead horse, but what is the best way to remove the brown residue from an aluminum manifold while it is still on the engine.
Tried carb cleaner, brake cleaner, paint thinner and acetone with zero results.
Brake cleaner with a kitchen 'scratchy pad' works just fine.
follow directions on bottle, repeat several times.
Received 6,521 Likes
C2 of Year Finalist (track prepared) 2019
Any product containing phosphoric acid will brighten aluminum. Aluminum Jelly, Alumiprep, Metalprep, etc.....
Jim
Jim
stains on aluminum manifold
Bluzrocker
Has anyone tried oven cleaner?
what,
none of the eleven methods described above (not including oven cleaner) worked?
Received 1,119 Likes
2017 C2 of Year Finalist
If none of the above methods work, give up, take it off the car and put it in the dishwasher on "scrub" or some such setting, with your normal dishwasher soap. Just don't let your wife know what's cooking
Received 1,857 Likes
Brake cleaner.
I can report that brake cleaner, simple green and carb cleaner have failed to remove anything other than dirt from the aluminum manifold.
Oven cleaner was not tried because the label said not to use on aluminum.
