C 1 rim width
Old 01-22-2013, 09:31 PM
tach drive 61
tach drive 61's Avatar
Default C 1 rim width
what is the widest rim that can be used on a 1961 front /rear , i know the stock ones are 5 " and the big brake option ones are 5.5" .I have used the 6 "x 15 on back . 6x15 with a 215 tire ??? on front is my question !
Old 01-22-2013, 09:40 PM
wmf62
wmf62's Avatar
St. Jude Donor '07
an 8" will fit on the front but in the rear the outside of the tire will hit the wheel well lip. i suggest 7" all the way around.
Bill
Old 01-23-2013, 12:49 AM
narlee
narlee's Avatar
For 75 and 70 series tires 7" is the widest recommended wheel.
Old 01-23-2013, 07:35 AM
gbvette62
gbvette62's Avatar
Received 2,023 Likes on 1,312 Posts
I've run 15X7's with 225/70R15's, on my 62 for years. The tires use to just barely touch the rear fenders, on a big bump. When I needed new tires, I went down to a 215/70, and all is good now.
I've know people who've gotten away with using 8' rims, on 61/62's, usually factory 15x8 rallys. There was a guy in a Corvette club I belonged to years ago, with FR70x15 BFG T/A Radials on his 62. I don't remember him having any clearance trouble, but the rear of the car may have been raised slightly, it was the 70's.
Old 01-23-2013, 08:05 AM
Frankie the Fink
Frankie the Fink's Avatar
Received 7,082 Likes on 4,736 Posts
Army
As long as you understand the extra steering effort required with fatter tires on a stock C1 front end...
Old 01-23-2013, 02:01 PM
steampunk c1
steampunk c1's Avatar
7 inch with 3.5 backspace is about max. I have 17 on front and 18 on rear 215 55 and it is tight at that.
Old 01-23-2013, 03:48 PM
tach drive 61
went down to the 215/70 ,steering was better as well . .there was a set on KH 15X6 rims on ebay FS $40 /4 of them clean . but pickup only in weatoge Conn> way to far for me .few hours left !
Old 01-23-2013, 09:05 PM
wmf62
wmf62's Avatar
St. Jude Donor '07
i ran stock OEM 8" rallies (4" backspacing) all around but had to raise the rear with airshocks to get tire clearance. i now run 7" aftermarket rallys all arounf with 4-1/2" backspacing; if i were to do it again i might consider 4" backspacing.
Bill
To C 1 rim width
Quick Reply: C 1 rim width
