Door Panel thread repair
Gentlemen,
I have my 1966 door panel and door off to do a hinge pin repair.
The fiberglass threaded holes in the door that hold the door skin are getting a little sloppy. Anybody have any tricks to rebuild these threaded holes? Same issue with kick panel screw holes.
I was thinking of JB weld and a toothpick to reduce the threaded hole diameter. Plastic wall anchors?
All suggestions considered
Randy
Randy
You could use zip ties to fit in the hole and then run the screws in, cut off the excess....
No mess..
No mess..
Received 6,946 Likes
2015 C2 of Year Finalist
Fill the holes in with epoxy of your choice. The re-drill the hole
I just installed the door panels on my 65 yesterday. There isn't a single screw that goes into fiberglass. The 3 across the bottom and the 2 by the hinges all go into metal plates that are riveted inside the door.
Jim
Jim
C2 of Year Finalist (track prepared) 2019
2017 C2 of the Year Finalist
I put a thick paper clip in the hole.... the screw will tighten up with the extra thickness of the papaer clip in the hole, you are snugging a door panel braket, not tightening a lug nut
I used a GM 2-part epoxy to adhere the side exhaust cover insulators to the aluminum covers. Hard as hell when dry and easily driled and malleable. I am going to try it on my fresh air vent screw holes.
Ray
Ray
Now that I have my glasses on I see you are correct. However I did get some good tips for the kickpanels.
Randy
On my '62 that I did many years ago, I used "Nut-serts" with great success on my door panels, and any & every screw that screwed into fiberglass. I then used stainless steel machine screws after the nutserts were in place. Those door panels were ON there! I also used thin plastic sheets instead of cardboard; sent 'em to Al Knoch and had him make the door panels on them...
