66 door cylinder lock
Gentlemen,
The door lock cylinder on my 66 rotates when I try to use the key to lock it. The door panel is off and I can see the whole door lock retainer clip rotates. I have tried cleaning the lock linkage to minimize the effort which helped. Does the escutcheon prevent the cylinder from rotating or is it just a flange?
Randy
Randy
Randy,
As I'm recalling, the only thing preventing the lock cylinder from rotating in the opening is the friction developed between the escutcheon and the door itself. Here's a picture of the lock cylinder with the escutcheon installed (on the right hand side). I just replaced both of my locks and don't remember any provisions in the fiberglass itself to prevent the cylinder from rotating in the opening.
When the spring steel retainer used to hold the lock in place is installed, it normally has quite a lot of tension placed on the lockset. Maybe you could try a new retainer?
My recollection is that the round hole that the cylinder mounts in has a cutout that the rectangular part you see on the outside of the cylinder fits into and stops it from turning. It's definitely not just friction or they all would eventually turn and possibly damage the paint.
Here's a picture showing the part that fits into the door cylinder opening that keeps it from rotating:
St. Jude Donor '06-'07-'08 & '12-'13
the holes in the doors are round.
There is a 6 in black metal plate with a bow in it that slides in behind the lock to secure it in place and keep it from turning.
it has cutouts just like the cylinder above.
That's correct. I didn't trust my "recollection" so I looked up a post from John Z from a while back. Here's a picture he posted showing the plate that slides in to hold the lock. It's hard to see in the picture, but there is a small slot in the plate that slides over the raised portion I showed earlier. Sorry that I misled you about the slot in the door.
Mike Coletta
Thanks for the feedback and great picture. My issue is the red plate shown in the picture ( lock retainer clip) rotates with the cylinder lock. There must be a way to increase the friction between the clip and the door. Maybe I'll try to re arch the clip.
Randy
Take a pair of pliers and put a better bow in the middle on top and bottom..
If you look in picture you see the middle has the bow to apply the pressure against the two metal tabs on the lock
