trying to post pic of my latest projects
Old 02-05-2013, 06:38 PM
1Redctoo
1Redctoo's Avatar
Default trying to post pic of my latest projects
hope this works
Old 02-05-2013, 06:39 PM
1Redctoo
1Redctoo's Avatar
another pic
Old 02-05-2013, 06:40 PM
SpartyGW
SpartyGW's Avatar
Works. Whatcha working on? Rebuilding the tranny?
Old 02-05-2013, 06:43 PM
1Redctoo
1Redctoo's Avatar
trans numbers are visible I hope
Old 02-05-2013, 06:51 PM
1Redctoo
1Redctoo's Avatar
I started out ,swapping out the 383 stroker for the 327/300 I've been working on .
Then I noticed the trans leaking at the rear seal and the linkage was loose .
Now I'm going to put the heat shields on the exhaust pipes that have been missing .
OH , and the front calipers are leaking ,so I'm tearing them apart also !
Someone refered to it as "project creep" . I think I have a bad case of it .
Old 02-05-2013, 07:26 PM
robert miller
robert miller's Avatar
Received 1,762 Likes on 1,529 Posts
Default ttt
^^^ I know the feeling on that one. Robert
Old 02-06-2013, 12:05 PM
1Redctoo
1Redctoo's Avatar
now I've got the front calipers apart so I can rebuild them with the "O" ring style piston seals. The cylinders are sleeved so I think some 1500 grit paper will clean them up nicely . I think I'll paint the calipers with high temp paint while I'm at it . Also there is a shield that looks like it was once cadnium coated at one time . Do they make a high temp Cad paint for that ?
Any help and suggestions are welcome !
Old 02-06-2013, 04:13 PM
JohnZ
Support Corvetteforum!
JohnZ's Avatar
Received 1,857 Likes on 1,100 Posts
Where is the shield? Got a photo?
Old 02-07-2013, 06:45 PM
1Redctoo
1Redctoo's Avatar
its the shield behind the rotor . Now that I look at it , i guess it isn't cadnium , probably just painted black.
Old 02-07-2013, 07:06 PM
JohnZ
JohnZ's Avatar
The rotor splash shield was originally zinc plated, as was the caliper mounting bracket.
To trying to post pic of my latest projects
Quick Reply: trying to post pic of my latest projects
