Carb removal
Old 02-20-2013, 11:29 AM
FRED COURY
FRED COURY's Avatar
Default Carb removal
I'm having trouble removing my Holley Carb from the aluminum intake manifold. Don't want to damage the carb or manifold. Any suggestions or tricks for removing this safely will be appreciated!!
Thanks, Fred in AZ.
Old 02-20-2013, 11:33 AM
Frankie the Fink
Frankie the Fink's Avatar
Received 7,082 Likes on 4,736 Posts
Army
Usually a broom stick or ice scraper plastic handle other soft object leveraged under the body somewhere will be enough to pop it loose. Don't start prying under the carb with a screwdriver for Pete's sake.
Old 02-20-2013, 11:34 AM
FRED COURY
FRED COURY's Avatar
Thank you!
Old 02-20-2013, 11:42 AM
66jack
66jack's Avatar
You do have the 4 nuts removed, before the broom stick or driver prying starts
Old 02-20-2013, 11:45 AM
FRED COURY
FRED COURY's Avatar
Yes, of course. I have removed numerous carbs and this is the first one that is this stubborn.
Old 02-20-2013, 12:31 PM
toms silver 60
toms silver 60's Avatar
Agree with broomstick. All washers have been removed as well? Sometimes they hang up on threads.
Old 02-20-2013, 12:48 PM
MikeM
MikeM's Avatar
Received 1,843 Likes on 1,398 Posts
If some genius has glued that carb down with gasket sealer, you could cause some serious damage by prying on it.
If a gentle nudge with the broom stick doesn't move it, I'd start a thin putty knife between the gasket and manifold adjacent to the base plate to avoid bending or warping it.
Old 02-20-2013, 01:08 PM
DansYellow66
Support Corvetteforum!
DansYellow66's Avatar
Received 2,621 Likes on 1,953 Posts
[QUOTE=MikeM;1583172780]If some genius has glued that carb down with gasket sealerQUOTE]
That was my first thought too.
Old 02-20-2013, 02:45 PM
Kerrmudgeon
Kerrmudgeon's Avatar
Received 4,583 Likes on 2,157 Posts
C1 of Year Finalist (appearance mods) 2019
You can also try a good tap with a rubber mallet, works to break it loose, for me anyway.
Old 02-20-2013, 03:51 PM
Frankie the Fink
Army
I hadn't thought about somebody gluing the carb down but I suppose I shouldn't be surprised if that were the case. The main thing is to not score the gasket mounting surface on the carb or manifold during removal. Then you have a whole set of new problems !
Old 02-20-2013, 04:35 PM
FRED COURY
FRED COURY's Avatar
Thank you to all who answered. It would seem that some moron used a sealer to install the carb.
Old 02-20-2013, 04:44 PM
Plasticman
Plasticman's Avatar
Fred,
When you do get it off, check that the surfaces are flat.
If someone used sealer, they either tried using a "used" gasket, or they were having leakage issues........carb mounting flanges have been known to warp (mostly from over tightening).
Plasticman
Old 02-20-2013, 05:55 PM
FRED COURY
FRED COURY's Avatar
Thank you , good points. Fred.
To Carb removal
Quick Reply: Carb removal
