Do 64's sit "rear end" low?
Right. That's what I thought also and then I spoke to a Corvette Restorer Guru who told me that 64 vettes were originally manufactured with a "tail low" rake to them. So, I'm trying to determine if there is any factual basis to his statement.
I'll take all the opinions I can get!
Rick
Rick
Do you have a picture to share so we can offer better opinions/ideas? Is your nose high? What are your floor to fender lip measurements for all 4 fenders?
2016 C2 of the Year Finalist
A nine leaf spring that will put your car to the correct height is the Eaton Spring made in Detroit. I just picked one up when I went to the Detroit Auto Show. Many vendors' springs that are offered are made in China and vary in the final ride height. I have a two year old Chinese spring from a well known vendor I'm replacing. Should be worth about ten bucks in scrap value.
The bolt that holds each strut arm to the inner center bracket is a cam type bolt. Loosening that bolt and turning it will pull your camber + or -.
Dave
Dave
Received 1,857 Likes
My 64 vette recently completed a "frame off" restoration. As I look at the car from the side profile, it appears to sit slightly "rear end" low! Is this correct?
Next question: What is the correct leaf spring? Is it a nine (9) leaf,
2-1/4" wide spring that has a 9/16" bolt running through the anchor plate or should it be a seven (7) spring, 2-1/2" wide spring that uses a7/16" bolt running through the anchor plate?
My rear tires appear to "bow" or "camber" in slightly at the top. Is this correct?
Regarless of spring, is there a rear camber adjustment? If so, are "shims" used? What is/are the camber adjustments.
My 64 came from the factory without "heavy duty" suspension!
Can any member help me. I really want to get it right!!
Hopefully, I have used the correct "technical" language. If not, I apologize in advance--please no rude comments.
Thanks,
Rick
Thanks,
Rick
The correct spring is 9-leaf (top 3 leaves flat, bottom 6 leaves cambered), 2-1/4" wide, with 9/16" bolts. 2-1/2"-wide springs and 7/16" bolts weren't used until the C3 era.
Rear camber should be set at 1/2* negative; it's adjusted with cam bolts at the inboard end of the rear strut rods. If there isn't enough adjustment left to bring camber into spec, the strut rod bushings have deteriorated and should be replaced.
OK, OK, you got me! But, really I need useful information, not comments like "Bull$hit". You tell me how that is helpful to understanding or addressing the underlying issue(s)!
Along the same lines, if my L84 fuelie had been ordered with the heavy duty suspension option, would the leaf configuration had been different? Ie, 7 leafs vs. 9 leafs; or some other configuration?
There's a "sticky" at the top of the index page that describes how to post photos if you're not a paid member.
Received 6,939 Likes
2015 C2 of Year Finalist
Heavy duity got you the 7 leaf rear spring. All others got the standard 9 leaf spring
#34
Hey Nowhere Man--and all other Members;
My car has the 7 leafs and is a factory L84 fuelie. It also was ordered with a 4.56 rear end and Nylon tires. In your professional and expert opinion(s), should I continue to use the 7 leaf heavy duty transverse spring ( or maybe a replacement if my spring is beginning to weaken); or, revert to the 9 leafs?
Please, everyone, submit an opinion!!
#35
If you don't mind the harsh stiff ride from the 7 leaf I would stay with one.
#36
Now you say it has a 7 leaf? Was the 7 leaf added at some later date? Remember the F41 option is more than just a 7 leaf spring.
#37
You have no photographs. You have no suspension ride height measurements taken according to the instructions in the Corvette service manual. You don't even have any incorrectly taken measurement to points on the body to offer. You have nothing but second hand opinion and personal observations to offer. I don't know how you expect anyone to help you.
#38
Hey Dan;
Please, if it's not too much to ask, REREAD the original set of questions and then tell me what information you need to answer the question.
Where did you read that I did not have pics or other data--you're simply jumping to conclusions. Engage your brain before going ballistic on me!!
#40
Hi A-Snake;
Having not been the original orwer of the car, I simply have no way to ascertain when the 7 leaf spring was added. I don't know if the dealer added it or some along-the-line owner. I just know that it's on the car now and has been for maybe 13 years!
