327 Block Differences?
What is the difference between the 1965 327 block ID 3782870 and the 1965 327 block ID 3858180. Both are small journals.
Can I use either one and rebuild a 327/350?
Received 1,843 Likes
The 180 block had thinner cylinder walls than the 870. The factory used the 180 block for engines 250-375 hp.
That is what I figured, thanks much!
They are offering the block and internal parts with double hump heads for $300. Other than visiable cracks and severe gouges in the cylinder walls, what else should I look for?
Are the main caps on the block?
The price is cheap enough.
Probably a different block. Scrap iron gets about 200 bucks a ton these days.
Where are the cracks and how deep are the gouges?
Looks like you'll get a pair of double humps for about 280 bucks, which is a fair price.
I hope you meant you were going to look for cracks and gouges, not that you had already seen some in the block?
Correct, I have now looked at it and no visible signs of cracks in the block and no gouging visible. everything looks fairly clean. So, I have the block, crank, pistons, heads and some extra parts all for $300, now it is time to rebuild it for a fresh motor. Thanks for all of your help.
Received 1,857 Likes
As I recall, all Flint-built small-journal 327's had forged cranks; the cranks for SHP engines were also Tufftrided for improved journal surface hardness, and were drilled/tapped for a balancer bolt.
Received 6,530 Likes
C2 of Year Finalist (track prepared) 2019
Basically it was the same crank as the large journal 307 cranshft and interchangeable with it.
That is good information. Thanks, I have a cast 327 crank, I was bummed when I pulled it out of a core engine and found the cast and not forged crank, set it aside and never measured. Now I know it should be a large journal. Time to go back and see if that block will make a 383!!! Maybe it is actually one of the rare 350's with the block vent? That would be pretty cool.
