L79 Distributor vacuum cannister
Can anyone tell me where to find the right vacuum cannister for a '65-67 L79?
A couple of years ago I located one at GMParts Direct but the part no. (I think) GM#88924985 is no longer listed
Corvette Central shows one, however I don't know if it really is right. What is CRUCIAL is the amount of vacuum to start the plunger. It NEEDS to be about 4Hg (3-5) . I mistankenly installed one that started the plunger at 8Hg and naturally developed a horrible stumble.
Another annoying question is whether or not there should or needs to be the short rubber sleeve installed on the plunger. This will limit the amout of vacuum advance and seems to be on some and not on others.
I really do not want to resort to intalling one of those ugly adjustable aftermarket cannisters.
Any help with this would be greatly appreciated.
Thanks,
Bob
Thanks,
Bob
Received 1,240 Likes
2022 Corvette of the Year Finalist -- Modified
2021 C2 of the Year Winner - Modified
2021 C1 of the Year Winner - Modified
2020 Corvette of the Year (stock)
C2 of Year Winner (stock) 2019
2017 C1 of the Year Finalist
Based on this info, I think you need the B26 can...................
http://www.lbfun.com/warehouse/tech_...ance_Specs.pdf
Thanks.
So that still leaves me with the issue of the 'bushing'. ...whether to use one or not. Does anyone have any experience with this. It seems to me that the can I last received from GMParts direct came without one. ....but maybe I just don't remember correctly.
Bushing
There is no bushing. If you need to cut down the vacuum advance, just get a piece of 1/8" vacuum hose and push it over the actuating rod leaving about 3/16" of the rod exposed. That should be enough for the rod to fully engage the breaker plate--You may have to experiment for enough engagement of the rod. That piece of vacuum hose will cut out about 4 degrees of the vacuum advance. If you need more than that, you will have to braze up the slot.
RON
RON
Why some L79s DO NOT have this problem when using the "wrong" vacuum cannister is unknown to me although there may be a couple of reasons for this lack of a problem with some cars with the "wrong' cannister. Over-rich caruration and/or a higher than 'spec' initial timing? (12-14deg?) could be sufficient to 'cover-up' the problem.
I'm just rambling now on only one cup of early morning coffee. Experience has taught me that dionf it the way is was done originally is almost ALWAYS the way to go.
2018 C3 of Year Finalist
that's what I think , the wrong can will give the car a weak
response . search here for the papers that lars has posted
the list of what you need is there. I know the #is 236 but I
don't know if it's a b 26 or b28 that list will tell you.
I'm having trouble finding the B28. It is no longer available from GMParts direct and NAPA (and Echlin) no longer list the VC1810 (B28).
AutoZone still sells the B28 can as part # DV1810:
http://www.autozone.com/autozone/par...artNumber=true
