C2 Turn Signal Switch
Old 02-28-2013, 10:42 PM
irlrogue
8th Gear
irlrogue's Avatar
Default C2 Turn Signal Switch
I have replaced the turn signal switch twice in the last 3000 miles about six years. Can anyone suggest a good after market vender.
TJ
Old 03-01-2013, 01:59 PM
bluzrocker
bluzrocker's Avatar
Default turn sig swtich
Yea there is some discussion regarding that......for quite a while the ones that were in high demand and the most reliable were not avaible and several other vendos filled the demand...w/ some results were worse that than the prefered ones......LIC(long island Corvette part # 18-20-C is 90$ more for teloscopic one I think......Paragon corvette...probably have the prefered one...and there may be some FORUM members that have experiance installing them ..stuff has to be just so...so.. as you probably know..
Bluzrocker
Old 03-01-2013, 03:22 PM
mrg
mrg's Avatar
I had a problem with a replacement repro turn signal switch, too, on my '64. Seems the blinker portion of the repro switch was the weak point. The right side blinker stopped working.
After removing the turn signal cam to gain access to the curly-cue spring contact innards it looked like one of the larger CC springs was a bit too curved, compared to the other side. This spring was removed, straightened out and the switch reassembled. That fixed the problem. .. So far, so good.
Old 03-01-2013, 03:27 PM
JohnZ
Support Corvetteforum!
JohnZ's Avatar
Received 1,857 Likes on 1,100 Posts
What year? There were three completely different turn signal switch designs between '63 and '67.
Old 03-01-2013, 03:47 PM
RestoMike
RestoMike's Avatar
Location: Livin' large and havin' fun in wonderful Oklahoma
TJ
I've had good results purchasing my harnesses's from M & H Electric.
http://www.wiringharness.com/
Old 03-06-2013, 11:46 AM
irlrogue
8th Gear
irlrogue's Avatar
Default turn signal
John
It is a small block 67'
Old 03-06-2013, 01:04 PM
JohnZ
JohnZ's Avatar
John
Paragon and LICS should have a good switch, and so does Shee-Mar (www.shee-mar.com).
Old 03-06-2013, 05:46 PM
Mike67nv
Mike67nv's Avatar
2018 C2 of Year Finalist
2015 C2 of the Year Finalist
I bought one for my ’67 from Paragon last April. They claim the ’67 switch is made by the OEM manufacturer and it’s made in the USA. So far, no problems with it. If you are a NCRS member, Paragon will give you a 10% discount.
Old 03-06-2013, 07:10 PM
Dave Kitch
Dave Kitch's Avatar
TJ
I will be comparing replacement switches supplied by NAPA, Autozone and LICS to see the differences. The LICS switch is cheapest while the Autozone and NAPA awitches are highest price. However, the Autozone and NAPA switches contain a new upper bearing. My son owns an auto repair shop so I get his discount prices. He mostly uses NAPA electrical parts and has had few problems. I suspect that the LICS switch is foreign made. I am partial to the NAPA switch which is very expensive if you paid retail. Since I do my own restoration i'll pay a little more not to do it over.
Dave K.
To C2 Turn Signal Switch
Quick Reply: C2 Turn Signal Switch
