Speedo Gear: How To...
I need to change the speedo gear in my '66. I have the plastic gear, trouble is I do not know how to remove the existing gear. Do any of you have photos or videos of how to remove the old gear and replace it with the new gear?
Received 6,943 Likes
2015 C2 of Year Finalist
jack car up. remove speedo cable. remove 7/16 hex head bolt where the speedo cable connects to. remove plastic gear. reverse above process.
undo the the small bolt with keeper...
twist and pull the large part the cable was screwed onto...
do this slowly and the gear is inside that part..
reverse procedure....be careful...put a little grease on the plastic to hold in place as you put it back together...
Received 1,857 Likes
On your '66, the speedo cable connection is on the passenger side of the transmission tailhousing - looks like the photo below.
