Battery Relocation
Battery Relocation
I've read all of the threads that I could find regarding battery relocation to the trunk area (right rear just behind wheel well). In looking beneath my 62, I can't see any way to access the area from beneath to be able to install any kind of reinforcement to the floor of the trunk in that area or to install bolts. What am I missing?
I have looked at a number of battery relocation kits. I'm wondering if the fiberglass trunk floor should be "sandwiched" between the bottom of any battery relocation kit and a slightly larger aluminum plate on the opposite side of the floor to prevent eventual cracking of the fiberglass. If so, I don't see any way to access the "outside" surface of the trunk floor. Thanks for the response.
Thanks for the photo. My question is in regard to how the bottom tray in the picture is attached to the trunk floor. I don't have access to the underside so I'm curious as to what fasteners can be used (can't use a nut & bolt because of no access). Another question is how are your battery cables routed through the trunk floor?
St. Jude Donor '07
or use what is called a riv-nut, basically a threaded pop rivet.
see the grommeted hole that i ran the #1 welding cable, used for battery cables, through; cables are tied to abandoned brake line on the inside of the frame.
Bill
2019 Corvette of the Year Winner
St. Jude Donor '15
When I put the battery in my trunk I used these. Makes for clean install
http://www.detroitspeed.com/mm5/merc...ct_Code=120701
If you put the box as far forward as possible, one of the hold down bolts can be made accessible from under the car.
St. Jude Donor '07
it's raining and i might melt if i crawl under the car to look, but i think 2 or 3 of the holes are accessible from the underside in the location i placed my tray.
mine is where it is because of my windshiels washer fluid tank being mounted on the fenderwell...
btw, here's my bubba disconnect... (with bypass fuse to keep clock running...)
Bill
Bill:
Since my battery is covered, I placed a disconnect on the positive line behind the passenger seat, but then my seat backs fold forward so access is easy.
Charles
Charles
St. Jude Donor '07
i did it just to get the battery out of the way rather than the car getting-out-of-its-own way...
Bill
Something to consider is that marine applications use a fan and ventilation considerations in the battery box to "prevent explosions" when a battery is in a closed environment.
St. Jude Donor '07
Bill
