Clatter in engine...hydraulic lifters..GRRRRR...
I am new at this so bare with my and my explanation...
Not really sure if its the problem...but here is my diagnosis....
This engine has less than 500 miles on it....
This started last Saturday and I just dove into it this afternoon.
At idle NO CLATTER..at about 1500 rpm is when it starts and continues up into the higher range..."Most of the clatter on the Drivers side"
EXCELLENT OIL PRESSURE THROUGHOUT.
So i figured the valve lash need to be done again to get rid of clatter....
When i pulled the valve covers #1 IE were just a little loose...so i decided to run them all again, BOTH SIDES...
Put it all back together,fired it up and RATTLE IS STILL THERE....
One possible idea is that i used the 'old push rods' from the engine i pulled out of car...that engine had 15 thousand miles on it...the reason i pulled it is it was burning a lot of oil...
Could it be that some crap was lodged in push rod and came loose or a bent push rod or rods?
Any and all Suggestions/questions are welcome....
Received 4,583 Likes
C1 of Year Finalist (appearance mods) 2019
Just for a laugh check the inspection cover on the bellhousing. Don't laugh....it happened to me last summer. I was ready to tear the motor down until i found it got a little bent somehow and was hitting the flywheel and making a clatter.
If it is quiet at idle I would be thinking something other that the lifters. They usually are noisiest at idle when oil pressure is the lowest. The inspection plate as suggested above is one possibility. Are you still running an operating heat riser valve on the passenger side exhaust? Engine belts worn, loose or pulleys out of alignment is a possibility.
Received 1,843 Likes
Valve cover clearance
I had the same problem just after I got the engine back from the last rebuild. If you have had the rocker arms and nuts replaced, the nuts are a little taller then the orginal ones. I took off the valve cover and sure enough, I could see marks on cover where the nuts were tapping the cover.
Simple solution. You may have on a standard valve cover gasket. Remover and put on the thick one. They have it, just ask at Napa. The 1/8 or so of an inch made the difference. No tapping in 46,000 miles the last two years.
So, just take off a cover and look
Jack
Hi Jack,
Jack
Jack
rustylugnuts
Jack's observation is certainly worth checking out.
FelPro makes two thicknesses of SBC cork valve cover gaskets; I believe 5/32" and 7/32"; I ALWAYS use the thicker ones...
Morning all:::
I will check the FW cover plate later this AM
I have the thick felpro gaskets on
New factory style rocker nuts...
Why would this just 'ALL OF A SUDDEN START', if its the inspection plate?
Another question:
I am just out of curiosity going to pull the drivers side cover and inspect the rockers.
If #1 ie is loose again, what would be your suggestions/ideas as to the cause?
Another question:
You can also leave the valve cover on and use the poor man Stethoscope, a (long handled screw driver) putting the handle to your ear placing slotted end on cover, if the sound is deafening, your rockers are hitting your cover, if moderate I would say re-check your valve adjustments.
rustylugnuts
rustylugnuts
http://ca.search.yahoo.com/r/_ylt=A0...ope-41966.html
Morning all:::
Another question:
Another question:
Received 3,043 Likes
St. Jude Donor '05
Mightbe your lifter bleeding down after shutting off may not have been out of adjustment.
Is it a HR cam? Quicker ramp? Do it while the cars running and drive it.
If you're using the stamped steel valve covers and you put them on backwards, they will hit the rockers too.
You can also find the noisy rockers and rule out anything else by putting the heel of your hand on the valve spring end of the rocker and push down. If the noise goes away, that's the location of your noise.
If you find #1's loose again, you have the rocker nuts backing off as stated, stud pulling or something wearing down. Check the #1 studs for the number of exposed threads above the rocker nuts and see if anything looks different from the others.
Check the ball seat area of the rocker in question and see if you can find a crack opening up that lets the rocker flex when rpm goes up.
Like i said i am new to diagnosing....
WHAT IS HR AND QUICKER RAMP?
stock rockers
280 Comp Cam
The clatter/rattle is at higher RPM's at or above 1500...not at idle...
A loose or blown exhaust manifold gasket can sound like lifter noise. You have had the engine out and back in. Check your exhaust manifolds for a blown gasket or loose bolts. Just a thought.
Dennis
Dennis
Right, but have you used/torqued them more than once? I know this is gonna sound crazy, but when I replaced the head gaskets on my ZZ4/350 last summer the rockers kept loosening up and making noise. After re torquing them a couple of times I asked a local Corvette shop about my problem, and was told the nuts are now made with a slight "crimp" (for lack of a better word) in the internal dimension to keep them locked - the first time they are used. Apparently they are not reusable, once and done only. So, I bought a new set, put them in, and no more problems!
Sounds crazy, don't know if it's ZZ4 specific or not (how could it be?) and I'm sure I'm gonna get a load of comments on this............ but, all I can say is - It fixed my problem!
I reused the push rods, and rockers/*****, 'stamped steel'...new nuts...
