Hood release handle
You can try epoxy.
You can buy a repro handle... at least for 63's you can....
Those replacement handles have little Allen head set screws to hold it to the cable............ They're not like the original in that respect.
Not sure about other midyears.
Chuck
Chuck
It happened to mine last month. I used J B Weld and a small grub screw and taped a thread on the under side of the handle. Also I placed some notches on the shaft to aid it, once it set, so it wouldn't give way when set. Lubed the shaft too. Prep the handle and shaft before you stick it together. Then I let it dry before trying it. Works well now . Cheers Leigh
