Under car exhaust with side exhaust rear panel?
Hey all. Despite having made several mods to my existing sidepipes, I 'm still unhappy with the level of noise next to my ears. That being said, I personally think that no mid year is complete without sidepipes. That leaves me with the intention of doing what a couple others here have done, leave the sidepipe covers in place, weld tips in place, and reinstall the undercar exhaust. My question is, will I be completely choking my car if I leave the sidepipe exhaust panel on the car and "hide " the tailpipes underneath the panel, or am I
going to need to reinstall the undercar exhaust panel and exit the exhaust the way it 's supposed to go?? I 'm thinking ( hoping) that the tailpipe bend required to exit underneath the panel won't be any more severe in terms of restriction than the bends in the sidepipes? Input??
Steve
BTW - 2 1/2" exhaust, and new mufflers or other pricey options are not in my budget right now.
Steve
ratvet (01-19-2020)
I like the sound of my side pipes, but there are times that I would like to "turn them off". I don't like to wake up the neighbors if I leave early on a Saturday or Sunday morning, so it would be nice to be able to control the sound. I have had thoughts of installing a muffler between the headers and the side pipes, but make it switchable. Using an electric cutout to control the direction of exhaust flow I believe it is possible to direct the flow through the side pipes or through a muffler. When using the muffler the flow would go from the header into the muffler and back into the side pipe. There would be no exhaust system under the car. I have not taken any action on this idea yet, but I think it could be done with a small enough muffler that would sit just behind the side pipe as it attaches to the header. This muffler would have to have the intake and output on the same end. I am wondering if anyone else on the forum has tried this?
Dejavet
Dejavet
I've seen a few here install both side pipes and under car exhaust dual switchable systems. Would be funny to run up to know-it-alls and have them say one of them is fake, and you tell them to stand in the rear and rev it, then stand to the side and rev it. Hope to do this one day myself.
Coe56 (01-20-2020)
1 Post
my car had an under car exhaust with turn downs before the rear panel. The car appears to have had side pipes at one time, the exhaust panel was filled in solid, so when they took the sidepipes off they didn't replace the panel and just did a turn down bend out of the muffler. I never had any problem with performance with the car in this configuration...
To those of you who sent back (real) answers, thank you for your input. Jim, I've been following your posts for some time now and love the mods your making to your car. If you have any of the info available on your daytime running lights would you pm me?? Thanks again to all
Steve
Steve
Last edited by mid-year crisis; 03-26-2013 at 09:49 PM. Reason: sarcasm in previous answer
Cruise-In III Veteran
Steve,
Thank you! PM sent! Bought my DRL's from Web Electric Products...here's their web site: http://www.webelectricproducts.com/
Regards,
Jim
In God We Trust!
Regards,
Jim
In God We Trust!
In April I'm going with QTP electric cutouts, an undercar system dropping off to the rear of the half shafts. Looking forward to a bit of quite on long hwy trips and open s/p whenever. Just got my radio redone, maybe I"ll be able to hear if the guy fixed it.
MrTrim (02-01-2020)
alblosser (01-19-2020)
I had the same dilemma. SP to noisy stock system to quiet. I love the look of side pipes. After allot of thought I ended up using both the stock exhaust and side pipes. I used QTP cutouts with stock 2 1/2" pipes/mufflers from Corvette central. Sounds great with the SP just opened a little. The neighbors appreciate it. lol.
OP, if you are going to go side pipes, man up and do the real thing. With good body insulation in the Coupe, cabin noise is even with Stereo sounds. A better set of SIDE PIPES would cure your problem. Pilot Dan
To get my CC stock undercar to exit below the panel I cut an inch or two from the inlet elbow. I also removed the welded on outlet piece and then welded on a 90*. After looking at the SMALL inner baffle of these mufflers, I didn't think the 90* would hurt the performance much. I switch between the two system every couple years for variety.
Another old thread I'm resurrecting because I just got a 66 BB with side pipes and have the same Saturday morning wife/neighbors problem. So SS409 or Jim does the 90 degree turn down from the stock muffler get it low enough to prevent fumes in the cabin? Has it discolored the rear panel any?
Steve
Steve
