63 Muncie vs. Borg Warner
When in the 63 model year was the 4-speed trans changed from BW to Muncie. Mine was built in Oct. 62 so I am guessing it has the BW. Is one considered to be better than the other.
The switch took place about May 1st, 1963. The majority of 63's, came with the Borg-Warner.
I don't think there's much advantage of one over the other, especially when comparing the 1963 version of each.
I just got my transmission back yesterday from the transmission shop having it freshen up. I asked the guy this same question. He said he has been building 4 speed trans for over 40 years and he said he could not tell any difference one to the other. He said he had put several Muncie parts in my Borg Warner.
I've never heard about (or seen) the tendency for Muncie main shafts to twist like the T-10s. The T-10s however have a notable reputation for that problem. I have a lot of T-10 main shafts that are only good for tent stakes now. Maybe I just haven't paid much attention to Muncie talk, so I don't know if they suffer the same problem?
Verne
PS: The first shipment of Muncies was in early April to the Baltimore assembly plant for passenger cars.
My 62 has had that popping out of 2nd problem for years. I've learned to live with it because it's a random occurrence but I'm also frustrated that the 3 transmission techs who have checked out my BW T10 over the past 15 years have been unable to correct the problem.
I am no transmission expert but I just picked up my 62 Borg Warner for having it freshened up. I asked what was the best lube. He said "just a good 70/30 and don't use synthetic or it will pop out of second gear" I don't have anything to base this on but it is food for thought
Lube type will have little or no effect on the T-10 popping out of gear. the slider and gear tend to wear on those from rapid (and missed) shifts. usually 2nd gets the worst of it. the use of torque lock sliders ($30.00) will cure that issue in all but the worst cases. torque lock sliders have a small relief machined in the end of the "splines" to hold the gear in place.
Russ
Russ
Doms63 (03-03-2024)
Received 1,728 Likes
2018 C1 of Year Finalist
They need to go back to school. Simply replace the entire synchro unit plus the gear and your problem is solved. The T 10 was an inferior trans relative to the Muncie. The clutch teeth wear over time preventing the synchro unit to hold the gear in place. It pops out more easily on deceleration
I have Royal Purple full Syn in my Muncie. Initially I was unsure due to the same synchro reasons stated above by Dan. My trans is older but works very well but I had to replace the front brg recently. Because it's an older trans I explored splurging on the synthetic lube to be nice to it when refilling after the service. I spoke to an oline expert with a very good reputation who assured me that it would be fine. So in it went and all is well for MANY miles this summer. Just sayin'. May not be the best for everyone.
Frank
Frank
The right fluid does make a difference it seems.
In my VERY early '63 Muncie I would get an occasional grind when downshifting into second. As part of the side cover leak fix I refilled the tranny with Amsoil GL-4 lube and haven't heard that clash since.
Doms63 (03-03-2024)
