Panel Adhesive
Old 04-17-2013, 06:14 PM
tdishon
tdishon's Avatar
Default Panel Adhesive
I have a new front end coming for my 62.
I'm used to fiber-glassing everything, but have used SEM 39747 dual-mix panel adhesive for metal to fiberglass. 90 min work time and it sticks rather than runs...
Would this me a good panel adhesive for bonding strips, etc?
Or any specific recommendations?
Old 04-17-2013, 06:36 PM
tdishon
tdishon's Avatar
I also hear good things about West System six10 thickened epoxy adhesive.
Old 04-17-2013, 06:45 PM
65silververt
65silververt's Avatar
3M panel bond 8115 works very well.
Old 04-17-2013, 06:55 PM
tdishon
tdishon's Avatar
I was just reading an old post about 3m 8115 and 8219.
They all look workable. I have the gun already for the 3m
Old 04-18-2013, 04:48 AM
mike coletta
mike coletta's Avatar
Received 1,067 Likes on 513 Posts
The 8115 is very good to work with. You get a stable work time, and unlike the old style bonding adhesive, you can clamp (if you need to) tight, and still get the same strength. Older bonding required a minimum of 1/4" material (glue) to get full bonding strength.
Mike Coletta
Old 04-18-2013, 07:19 AM
outlaw67
outlaw67's Avatar
could also have a look at Lord Fusor , http://www.lord.com/products-and-sol...ives.xml/663/4
Old 04-18-2013, 11:26 AM
Scott Marzahl
Scott Marzahl's Avatar
I find myself using 3M 8115 anytime I need to bond something, used it for my '67 front end, worked great, 90 min work time which is nice when you are doing it by yourself.
Old 04-18-2013, 12:32 PM
mrg
mrg's Avatar
Lord Fusor 127EZ also good. 60 minute working time.
Old 04-19-2013, 12:07 PM
5869vette
5869vette's Avatar
8115 can also be heat cured.
Old 04-19-2013, 12:20 PM
tdishon
tdishon's Avatar
I ended up getting SEM 39747. I have used it in the past for metal to fiberglass.
I spoke to an industrial fiberglass manufacturer here in Phoenix. He said I could use it for fiberglass to fiberglass too. I had a few tubes of it left over here at the house. It is pretty thick and should work with a similar work time ad the 3m 8115.
To Panel Adhesive
Quick Reply: Panel Adhesive
