Help ID this Borg Warner trans
I have a Borg Warner T10 and need help decoding it. I did some searches but got confused about the yoke. Did '62 have a bolted yoke or could this be an early '63? Did anything else use a bolted yoke?
It has a 10 spline input shaft with 1 groove and the driveshaft yoke is bolted in.
Main Case is cast iron:
T10-1B
W.G. Div
Q2
6.20.62
Tail is aluminum
T10-7B
WG Div
5.19.62
Side Cover
6.19.62A
Build Date
WG2623
T10-1B
W.G. Div
Q2
6.20.62
Tail is aluminum
T10-7B
WG Div
5.19.62
Side Cover
6.19.62A
Build Date
WG2623
Received 1,857 Likes
T10-1B
W.G. Div
Q2
6.20.62
Tail is aluminum
T10-7B'WG Div
5.19.62
Side Cover
6.19.62A
Build Date
WG2623
T10-1B
W.G. Div
Q2
6.20.62
Tail is aluminum
T10-7B'WG Div
5.19.62
Side Cover
6.19.62A
Build Date
WG2623
I beg to differ. There were no iron case T-10s installed in 1962 Chevy passenger cars. With a '62 date and an iron case, it was from a Studebaker, Buick, Olds or Rambler. ALL 1962 Chevy passenger car 4-speeds had a T10-1C case.
Verne
Shows how much I know about full-size cars - I'll stick to Corvettes..
