63 battery issue
Received 1,858 Likes
What does your battery gauge indicate when the engine is running?
New batteries can be bad. I had abad battery in my 63 SWC several years ago and after taking it out I went and bought a new Interstate Battery. To tired to install it I did check it and it read 12 V at about 5:00pm and I put it in my wood work bench and the next morning re-checked it again just for kicks and I was glad I did, it was down to 10.5V so I took it back and got another one and did the same thing as far as leaving it set over night on my work bench. Next morning it checked out OK 12V and I installed it and was great till I sold it and I guess it is still fine. So yes, new batteries can be bad. Oh my old battery had a bad cell in it.
Thanks...I can tell you that while the meter was showing 12.6 with ignition off, even with car running it continued to show the same volts...and the ammeter in the car sows negative volts when using the windows, headlights, etc....but never shows positive volts...
Received 6,530 Likes
C2 of Year Finalist (track prepared) 2019
The Ammeter registers Amps, not Volts.
When the Ammeter needle swings to the left, current, is flowing out of the battery and vice versa when the needle swings to the right. Amps, indicated on the Ammeter tell you the rate at which current is flowing, either into or out of the battery.
Jim
thanks...I actually knew that...I simply was wanting to relate the fact that the meter was always showing negative flow when using anything electric on the car, but never shows a positive flow at any stage
let me restate my 4-5 day claim as I performed my own little test...I charged the battery and let it sit for 4 days then tried to start it...it started perfectly...after driving around for 2 days thereafter, the battery died...so it seems that if the car sits after charging, the battery holds the charge...it only seems to lose the charge after its been driven a bit. does this make any sense?
My guess would be alternator not charging. Simple test is to start engine and the disconnect the positive battery cable. If the engine dies--no alternator charge. If it keeps running you'll have to expand your search. Never showing a positive flow on amp gage also suggest alt. or voltage regulator. Good luck.
Do JohnZ's test in post #5 above. Disconnecting the battery on a running car is a very bad practice. It usually works on classic cars but is a real bad habit to get in to.
The battery acts as "ballast" in the charging circuit and needs to be there with the motor running:
http://www.troubleshooters.com/dont_...ct_battery.htm
I had a bad diode in my alt and it would bleed back when the car was off. It would still charge while running but only problem is when it sat. I disconnected the Alt and let it sit and found out it was the problem.
Thanks...it's as a I though...meter showing constant volts around 12.6... Replaced the voltage regulator and still the same....must be a bad alternator....thanks for everyone's advice!
