Borgeson Hoses
Borgeson Hoses
Just finished my Borgeson install and my only complaint is the hoses are not very flexible and the return line is too short
(or the high pressure is too long) depending on how you look at it.
Apart from making a new (longer) return hose, how can you clean this up ?
At the moment, the hoses are touching the upper control arm and the high pressure elbow hits the frame
That's strange, I found the return line too long on mine and we actually cut off about an inch. I hear the best way is to replace the hoses supplied with the more flexible stainless lines.
Don
Don
