Hurst for my 63?
Hurst for my 63?
I have a 62 340hp 4speed Borg Warner . My Early 63 fuelie has a Borg Warner too. My 62 has a hurst shifter that really works good. I have seen 2 or 3 on ebay for the 62 but all the 63s (hursts) are for muncies . My question is will the 62 hurst work in my 63? The hurst (62) is the bent short shaft style. 864-380-4796 or dcrocker316@gmail.com
St. Jude Donor '07
while i can't be absolutely sure, i believe it will; the transmission is the same and the shifter mounting position on the tailshaft should be the same.... so, it should work
Bill
Bill
Received 6,528 Likes
C2 of Year Finalist (track prepared) 2019
As I recall, the Hurst shifter for a '63 has a reverse lever that has a 90 degree bend to clear the crossmember. If a "62" shifter has this feature, it should work.
I believe you'll need to buy an install kit specific to your trans and vehicle, though.
Jim
Jim
Hurst shifter
Any one out there ever put a 62 hurst on a early 63 , both having a BW 4 speed. Thanks for your quick response . Also does anyone have a 62 shifter I could try. Probably need linkage too. Dave 864-380-4796
Received 1,843 Likes
The stock B/W shifter is the same way. One year only.
