Transistor Ignition or not?
Where can I look for the ignition distributor code to check if my 65 has transistor inginition option or not (K66)?
1111069 365 Horsepower 327 Engine
1111060 365 Horsepower 327 Engine with K66 Transistor Ignition
Thanks,
-Matt
Thanks,
-Matt
T.i.
Look at the wire coming out of the bottom of the distributor. As long as nothing has been modified, if you have a single black wire you have regular ignition. If you have a double white wire with a plastic connector at the end you have transistor ignition. The part number tag is wrapped around the distributor body just above the intake manifold---if it is still there.
RON
