64 engine code question
Please help me understand the difference between the RE and RT codes for 64
RE = 327-cid 365-hp V-8 with 11.0:1 compression ratio, manual transmission or special high-performance manual transmission, and four-barrel carburetor
RT = 327-cid 365-hp V-8 with 11.0:1 compression ratio, manual transmission, and four-barrel carburetor
RE and RT are both the same except for one transmission option available with RE? I suppose then I have to check the trans code for VIN and type?
I'm planning to look at a 365 HP 64 in the next couple days and this could be a key factor in making an offer.
Thanks,
Thanks,
Received 6,943 Likes
2015 C2 of Year Finalist
RT has RPO K66 T.I. ignition. RE has points
Oh, very nice. Thanks.
One car I am about to go see is supposed to be a RT car then. Any advice on what to look for besides the stamp pad? Details please...
Look for the T.I. parts and if in working order. The system can cost a bunch of $$ to replace if missing or not working.
