1962 corvette engine help?
Old 06-02-2013, 05:34 PM
wnordstrom
5th Gear
wnordstrom's Avatar
Default 1962 corvette engine help?
My 1962 corvette that I recently purchased has a block# 3849852 which is a 283. But it also has a manifold# 3795397 which is an aluminum 4bbl manifold for a 327 340 hp. Can anybody help me figure this out?
Old 06-02-2013, 05:37 PM
Nowhere Man
Nowhere Man's Avatar
Received 6,920 Likes on 4,770 Posts
2015 C2 of Year Finalist
What do you want to know. Just about any SBC intake will work with just about any heads and block. If you want to know what the engine block started out as on the passenger side in the front of the block right below the cyl head there is a machined pad. Called the stamp pad. If there is any numbers there post them and someone can decode it for you. If nothing there then you have no clue what it was
Old 06-02-2013, 05:38 PM
wmf62
wmf62's Avatar
St. Jude Donor '07
apparently someone has changed the engine... what is the redline on the tach, the original engine may have been a 340 and someone used the original manifold.
Bill
Old 06-02-2013, 05:43 PM
wnordstrom
5th Gear
wnordstrom's Avatar
The numbers I can find are as follows
Serial no. 20867S108187
Block# 3849852
Eng code 805423854
Carburetor is a Rochester 4 jet
Manifold # 3795397
The car is still in storage so I am not sure what the redline is on the tach. What should it be for a 340 hp
Old 06-02-2013, 06:03 PM
wmf62
wmf62's Avatar
St. Jude Donor '07
Bill
Old 06-02-2013, 06:19 PM
wnordstrom
5th Gear
wnordstrom's Avatar
Just went out to the sea-can and its redline is at 6400rpm. Can't wait to get it out and running for the summer!!
Old 06-02-2013, 06:24 PM
wmf62
wmf62's Avatar
St. Jude Donor '07
the engine could be anything; without taking it apart you will never know for sure..
if it runs good, leave it alone and enjoy driving it..
Bill
Old 06-02-2013, 06:41 PM
wnordstrom
5th Gear
wnordstrom's Avatar
Yeah it runs great, I would like to know just for peace of mind.
Old 06-02-2013, 07:54 PM
wmf62
wmf62's Avatar
St. Jude Donor '07
gonna be hard to tell without pulling a head off...
Bill
Old 06-02-2013, 08:10 PM
JohnZ
Support Corvetteforum!
JohnZ's Avatar
Received 1,856 Likes on 1,099 Posts
That block was used only in '58-'67 passenger car and truck 283's, never in Corvettes; most likely a hydraulic-lifter 2-barrel Powerglide engine.
To 1962 corvette engine help?
Quick Reply: 1962 corvette engine help?
