1954 body restoration
That turned out really nice
There's just something hot about bare glass!
The main body is stripped with sanding material. The blast media is copper slag called Sharp Shot, fine grading. We only use it for the nooks and crannies. Should be set to about 50-60 psi, low, just to get the paint off but not enough to hurt the fiberglass.
We already got the front end from Corvette Image here
Received 1,436 Likes
C1 of Year Finalist (stock) 2019
2018 C1 of Year Finalist
front end doesnt look that bad....
but if you are going to replace the front end - section it under the windshield..
also you will have to add material to the lip at the firewall - those are normally cut short....
