FS: SBC 350 Engine - ALL NEW REBUILD
Phone: 847-847-1546
[/B]
Motor Specifications
1. 1970 Lt-1 block & heads. (GM 3970010)
no #'s stamped/replacement block, heads.
2. Bore 4.040
3. Stroke 3.48
4. Block align honed,decked and cylinders deck plate honed.
5.Heads matched ported and bowl blended.
6. Eagle rods with ARP bolts.
7. Balanced Eagle cast crankshaft.
8. Clevite rod and main bearings (.003 mains&.002 rod clearance).
9. Speed Pro Hyper pistons, 7cc dish 9.8cr w/64cc heads.
10. Comp-Cams Xtreme hyd. camshaft #XE-274H .490 lift.
11. Comp-Cam springs,1.5 ratio roller rockers, Comp-Cam Magnum hyd
lifters and CV products push rods.
12. Comp-Cams roller time chain.
13. Fresh valve job with back cut intake and exhaust valves.
14. Edlebrock dual plane manifold and 750cfm Holley vacuum secondary
carb.
15. * Corvette cast iron mag pulse
dist. with mechanical tach drive*
16. Fresh rebuilt Moroso aluminum water pump.
17. New Melling oil pump w/steel shaft and all Fel-Pro gaskets.
18. Starter
19. Alternator
$4,000 or best offer
[/B]
2. Bore 4.040
3. Stroke 3.48
carb.
18. Starter
19. Alternator
