rear axl leak. Wanted to make sure I have the right fluids???? 1959 vette
Hello,
My rear axl has a leak and I was going to refill it and try to fix it this weekend.
I just wanted to make sure I had the right fluids so I don't mess anything up.
First, Is there a difference between gear lube & gear oil. The manual says gear lube.
This is what I bought from NAPPA. They were not to familiar with 59 Vettes but they said this would work. I want to know for sure I am putting the right stuff in.
I bought:
Valvoline High Performance Gear Oil SAE 80W-90. Limited Slip
Trans-X Positrac Limited Slip Gear Oil Additive GM#1052358.
Thanks in advance for any help you can provide.
Dean
PS I didn't know if I had Posi trac or not but a few people has said it would not hurt anything to put the Posi-trac Gear Oil Additive with the regular gear oil.
I bought:
Dean
it's got a posi, or limited slip.
The oil is fine, but I don't know about putting posi additive in an open diff.
St. Jude Donor '07
if the test above determines it to be positraction, use the additive; if not, return it for a refund.
adding the additive to a non positraction rearend will not cause any harm, but why waste the $$$
Bill
Bill
Received 3,769 Likes
2023 C1 of the Year Finalist - Modified
2015 C1 of the Year Finalist
Dean,
PM sent.
PM sent.
