1957 Corvette clutch replacement- any tips?
Old 06-22-2013, 09:55 PM
128racecar
128racecar's Avatar
Default 1957 Corvette clutch replacement- any tips?
After 56 years, the original clutch in my 1957 Corvette gave up the ghost. My plan is to pull the tranny, clutch, and flywheel. In addition to refacing the flywheel, I also plan to replace the transmission input, tailshaft, and side cover, and rear end pinion seals as well as the shifter linkage. Any tips for the R&R process? Likewise, best way/ locations to support the rear of the engine when pulling the tranny? The tranny has never been out in the past, so I have already soaked all the various nuts and bolts with penetrating fluid.
Thanks from a forum newbie
Marc in Indianapolis third owner (my dad bought in 1962)
1957 Corvette EH 245 HP 4 spd posi semi-survivor (repainted/reupholstered in the 80s)
Old 06-22-2013, 10:07 PM
1snake
1snake's Avatar
Since the original lasted that long, replace it with another one. Luk #04-084. Carolina Clutch has the complete set up for under $120.
Jim
Old 06-23-2013, 08:03 AM
MikeM
MikeM's Avatar
Received 1,843 Likes on 1,398 Posts
Originally Posted by 128racecar
I also plan to replace the transmission input, tailshaft, and side cover, as well as the shifter linkage. Any tips for the R&R process?
Why are you replacing these parts? Just curious.
Don't forget to change the crankshaft pilot bushing. Replace with a real oilite bushing.
Old 06-23-2013, 12:07 PM
Redbird
Support Corvetteforum!
Redbird's Avatar
2021 C2 of the Year Finalist - Unmodified
C2 of Year Finalist (stock) 2019
2016 C2 of Year Finalist
Wow! How many miles on the setup?
Old 06-23-2013, 12:34 PM
128racecar
128racecar's Avatar
Oops! Forgot to mention I was going to replace the tranny and rear pinion SEALS. Big difference! They leak like a sieve. Total miles unknown. My dad replaced the speedometer/odometer with a new one in 1962 because it was broken. I have no idea how many miles were on the car at the time. Only 2100 miles since. Yea, I know it comes out to only 41 miles a year. i have let it sit for way too long while other family, business, and car projects came first. Time to wake up Sleeping Beauty.
Marc
Old 07-15-2013, 08:57 PM
128racecar
128racecar's Avatar
Finally got this bad boy out. First light of day for it since 1957. Thank goodness my 23 y.o. son was there when the moment of truth came in sliding it out. Next up is the clutch and flywheel. One deviation I would recommend from the factory shop manual is to remove the crossmember before tackling the three bolts that hold the shifter in place. It gives a little bit more room to get to those bolts. I think I also discovered the source of the whomp-whomp-whomp when I got on it hard. Note the stripped out bolt holes for the tranny mount. Basically the tranny was just resting on the mount, not really attached to it. Will keep everybody posted!
Marc in Indy
Old 07-16-2013, 09:00 AM
ack fia
ack fia's Avatar
Default Clutch Replacement
Just DO NOT USE a flat face diaphram pressure plate. Your "over center spring" will never work if you do.
Old 07-16-2013, 09:28 AM
69z28&ss396
69z28&ss396's Avatar
mmmmm greasay!!!
Old 07-16-2013, 07:29 PM
128racecar
128racecar's Avatar
Is this okay? I hope so, as I bought it from a major Corvette supplier a couple of years ago. I know about the over-center spring, but please educate me how it affects the pressure plate selection, and what to look for in a pressure plate.
Marc in Indy
Old 07-16-2013, 07:38 PM
128racecar
128racecar's Avatar
Are you talking about the fingers on the diaphragm where the throw-out bearing comes in contact? On this model, the fingers are bent, not straight. Just want to double check before I wrestle this moose back in.
Marc in Indy
Old 07-16-2013, 07:51 PM
wmf62
wmf62's Avatar
St. Jude Donor '07
this is what a flat-fingered pressure plate looks like; yours is correct.
Bill
Old 07-16-2013, 07:53 PM
128racecar
128racecar's Avatar
Thanks!!!
Marc in Indy
Old 07-16-2013, 08:45 PM
JohnZ
JohnZ's Avatar
Received 1,856 Likes on 1,099 Posts
Thanks!!!
Marc in Indy
Make sure you use the correct (1-1/4"-long, NOT 1-7/8" long) throwout bearing, and ensure that you install it correctly on the clutch fork, with the ends of the flat spring inside the rear groove on the bearing, with the ends of the fork. The design allows it to be installed wrong.
Old 07-17-2013, 06:23 AM
finleyeagle
finleyeagle's Avatar
Hi Marc,
Nice to hear of another 56,7 solid axle owner in the area. I have a couple 56's and have owned other 56 and 57's. Give me a call if you want to discuss the old cars.
Thanks Mike (317)729-2418
Old 07-18-2013, 07:37 AM
mashinter
mashinter's Avatar
It's been a long time, but I think I cut the heads off two long bolts that I used in the bellhousing trans bolt holes. That allowed me to hang the tranny while I fiddled the splines into engagement; trans in gear so turning the ouput shaft would turn the input shaft.
Old 07-18-2013, 07:54 AM
Frankie the Fink
Frankie the Fink's Avatar
Received 7,082 Likes on 4,736 Posts
Army
Its a perfect time to go through the entire clutch geometry/linkage. Ball studs at engine and frame (yours simply have to be worn out I'm thinking); clutch fork and its ball stud, even the upper clutch pedal bushings/spacers under the dash. When I put my 5-speed in the '61 ALL of that stuff needed refurbished.
Might be the time to resurface the flywheel and either flip or replace the ring gear too!
Old 07-18-2013, 04:48 PM
stratplus
stratplus's Avatar
Yes, this might have been a JohnZ trick and it works very well.
To 1957 Corvette clutch replacement- any tips?
Old 07-19-2013, 03:55 PM
128racecar
128racecar's Avatar
Ok, now the flywheel is at the machine shop- they want to know if it is a stepped or flat face design. The senior machinist thinks it already has a .040 step but he doesn't have a reference that goes that far back, and he wants to be 100% sure before he cuts it. There is no mention of flywheel resurfacing in either of my two shop manuals.
Marc in Indy
Old 07-19-2013, 04:11 PM
wmf62
wmf62's Avatar
St. Jude Donor '07
Marc in Indy
i have never seen a 'stepped' one, so i say 'flat'
Bill
Old 07-19-2013, 04:58 PM
Frankie the Fink
Army
I'm pretty darn sure it is flat - here is my '61 after resurfacing and new ring gear:
Quick Reply: 1957 Corvette clutch replacement- any tips?
