E-Brake cable connection
Old 06-25-2013, 12:35 PM
66DCJR
66DCJR's Avatar
Default E-Brake cable connection
My 66 has the e- brake cable running through the cross member. On the rear side there is a welded clip to the crossmeber where a bolt goes through and a nut attached to capture the outer portion of the cable. My question is what portion of the cable goes up into this clip? Is the very end of the outer casing or is the outer shell with the wire wrapped around ?
Old 06-25-2013, 01:00 PM
66jack
66jack's Avatar
Does your car have all the parts for the e-brake at the crossmember?
http://www.parts123.com/parts123/yb....Z5Z5Z50000050B
Old 06-25-2013, 01:27 PM
66DCJR
66DCJR's Avatar
Yes, all parts are installed correctly as shown. Need to know what portion of the cable actually fits into the welded clip. The cable fits into clip with bolt under it I beleive, but not sure if the very end of outer casing or the outer casing portion that looks like a spring wrapped around.
Old 06-27-2013, 04:02 PM
BT427
BT427's Avatar
Here's how mine was configured. Never been touched.
bob
http://i41.tinypic.com/j0h6wz.jpg
Old 06-27-2013, 07:06 PM
66DCJR
66DCJR's Avatar
BT427 , Thank You ! Exactly all I wanted to know . Excellent photo .
Regards
66DCJR
Old 06-27-2013, 07:58 PM
1snake
1snake's Avatar
Here's a pic. of my 65, never been touched.
Old 06-29-2013, 07:23 PM
66DCJR
66DCJR's Avatar
1snake.
I secured it today. No problem.
Thank You,
To E-Brake cable connection
Quick Reply: E-Brake cable connection
