1965 327/350 carb gasket question
Cruising
I have a 4150 2818 holley carb on my 65 327/350. Can anyone tell me if I should just have the regular gasket for the intake manifold or if any additional gaskets/seals are required? It looks like all the other engines call for a baffle, does mine?
Received 1,857 Likes
Nope, not if you have the stock 461 intake manifold - all it gets is the gasket. Make sure you use the correct 3-hole gasket.
