Troubleshooting experts, enter.
Old 07-16-2013, 04:27 PM
  #41
1snake
1snake's Avatar
I guess what threw me and everyone else there was:
1. Brand new everything including the battery.
2. Battery was fully charged and working perfectly when I disconnected it.
3. Battery indicated to be fully charged when I hooked it back up. Why wouldn't it be?
4. Power at the engine side of the firewall plug but none inside the car, not even enough to light a dome light, even an almost dead battery would still light one up.
Logically, everything points to the firewall plug.
It obviously was in the back of my mind somewhere that the battery might be the issue or I wouldn't have brought a know good battery back with me even though the one in the car was "known good".
Thanks for playing.
Jim
Old 07-16-2013, 04:29 PM
  #42
steveale
steveale's Avatar
Jim,
Don't let the battery company know about your secret or the warranty is void....
Old 07-16-2013, 04:30 PM
  #43
wmf62
wmf62's Avatar
St. Jude Donor '07
Jim
that just doesn't make sense to have power on one side of the 'plug' and not the other///
Bill
Old 07-16-2013, 04:42 PM
  #44
Ironcross
Ironcross's Avatar
Originally Posted by 1965fuelie
You have a bad connection somewhere. Checking for tightness isn't good enough. You have to clean the connections and reinstall.
check and clean the ground connection from the battery to the frame....many owners don't even know where the connection is...{short cable from battery to frame under or near the drivers seat}
Old 07-16-2013, 04:47 PM
  #45
1snake
1snake's Avatar
Originally Posted by wmf62
Jim
Bill
The reason it was like that was I checked for power on the engine side with the door closed so it read 12.9 volts but when I opened the door, the dome light put a load on the battery causing it to read zero so there was no power at the fuse box. Had I left the door open and gone back to check the engine side again or even directly at the battery, it would have read zero.
Jim
Old 07-16-2013, 04:52 PM
  #46
1snake
1snake's Avatar
Not on a C-2. The neg. cable goes directly to the outboard starter bolt. The answer is in post #34.
Jim
Old 07-16-2013, 05:02 PM
  #47
wmf62
wmf62's Avatar
St. Jude Donor '07
Jim
, just dumb luck/stuff happens...
Bill
Old 07-16-2013, 05:10 PM
  #48
1snake
1snake's Avatar
Bill
Now you understand why it was so hard to figure out. Something as small as a dome light caused the battery to temporarily read zero, otherwise it read fully charged even though it wasn't. A lead acid battery would never do that, but then again, the manufacturer says an AGM battery won't do that either, but it did, to me, on a hot day at a car show. Lucky me.
Jim
Old 07-16-2013, 05:49 PM
  #49
wmf62
wmf62's Avatar
St. Jude Donor '07
Jim
i'd have tried to check it with a 12volt test light, so maybe it would have acted like your dome light and i wouldn't have shown a circuit; therefore by dumb luck, i'd have said 'battery'...
or not...
Bill
Old 07-16-2013, 07:01 PM
  #50
1snake
1snake's Avatar
or not...
Bill
In hindsight, that would have shown the problem IF combined with the use of a volt meter because the test light wouldn't have lit up making you think it was broken especially when the volt meter shows 12.9 volts. You would then have had to check the test light for proper operation on another car. Then you would start to see the problem. Confusing as he11. I prefer to use a volt meter because that will tell you the exact state of charge of an AGM battery. 12.8+ volts fully charged, 12.6 -12.7 80 %charged down to 12.3 which would be almost discharged but would still brightly light up a test light.
Jim
Old 07-16-2013, 07:57 PM
  #51
goodwood67
goodwood67's Avatar
Buy a new set of battery cables.
Old 07-16-2013, 08:01 PM
  #52
1snake
1snake's Avatar
They are new. The issue was with the brand new battery. Read post #34 where I explained it all.
Jim
Old 07-16-2013, 08:09 PM
  #53
Westlotorn
Support Corvetteforum!
Westlotorn's Avatar
Received 1,275 Likes on 815 Posts
Thanks for sharing, I am not a fan of AGM batteries, although I have read many advantages, My wifes X5 now 4 years old has an AGM, she told me her air conditioning would not work, I went at it trying to find the source. I could find nothing wrong, I tested the battery voltage and had 12.5 and thought all was good. Did some reading on the INTERNET and found out the Smart Vehicles today see a voltage drop and start shutting off systems to keep the car on the road, one of the first to be shut down was the A/C system to protect the battery power available. After wasting several hours I ended up buying a new battery and all works well again. The X5 starts thinking you are in failure mode when you get down to 12.5 volts. I really don't need a car that thinks for me, it really pisses me off when I try to diagnose using old school skills. I feel your pain and I am glad you figured it out. This will be a memorable car show for you, a reason to laugh over a beer in future.
Old 07-16-2013, 08:37 PM
  #54
1snake
1snake's Avatar
That was the point of my post. For us old school guys, nothing made sense so think outside the box. Absolutely no test or history of the vehicle/parts pointed towards the battery. As far as the beer in the future, I've been drinking heavily since.
Jim
Old 07-17-2013, 04:45 AM
  #55
EDinPA
EDinPA's Avatar
This is why I have a battery load tester. The voltage reading at the battery is nice to know but is a not a guarantee of a batteries health.
Old 07-17-2013, 07:34 AM
  #56
Matt Gruber
Matt Gruber's Avatar
had a similar failure. battery has rivets connecting each cell to the next. rivet broke. current flows thru acid only, so tiny bulb dims. Took off caps. i stuck in a screwdriver (dangerous) while i tried to crank. wiggled it and it fired right up.
Quick Reply: Troubleshooting experts, enter.
