"Corvette Correction Chassis tire choices" what's yours?
For those that have chosen Billy Dawson's Corvette Correction aftermarket chassis for your restomod, or stock appearing C1...what tire did you decide on.
I'm particularly interested in the aspect ratio and height dimensions. ...and as always pics sure are nice if you have them, but the "real" tire dimensions are more important.
I know what I would like appearance wise...but not sure what would best for a reasonable turning radius.
Thanks...Stan
Thanks...Stan
C5 wagon wheels with 245/45R17 on the front
For the more traditional look - steel '95 Camero wheels 7.5" X 16" with real two bar hubcaps, 215/65R16 tires.
Loren Smith (04-07-2022)
Hello again Charles and thanks for the input. I don't know whether the difference in frames would make a difference in the turning radius on the front. Does it?
How do you like the turning radius with the 245/45/17's on Billy's chassis? ...and what is the backspace on those wheels?
Thanks..Stan
Thanks..Stan
The 17" wagon wheels have a 7" backspace.
The turning radius on Billy's frame is OK, would be nice if it were sharper, but it is what it is. I have never actually measured the turning radius compared to a stock frame.
Charles
Charles
Charles...
Wow ..7" backspace ???
I would have guessed that it would hit the frame real quick.
One set of wheels I have has 5.5" backspace and looks like they may hit the frame a little early. I ordered the early C4 suspension (smaller rotors) so I could run 15's if I wished.
The cutout on the C.C. frame would allow more turning radius if my tires were a little shorter (maybe an inch). They are 225/70/15's....but they hit the frame before the cutout.
Thanks..Stan
Thanks..Stan
I just put 235/55 17s on mine. I had 215 & 225/70 15s on it and they rode and drove great but I wanted a little more tread on the ground and a different wheel. I just road tested the setup and I like it. I have 87 suspension so I had to add 15mm spacers in front and 20mm in back for tire to frame clearance with 8.5" Z06 wheels.
Bud
Bud
Bud
Bud
Thanks..Stan
Stan,
It does not make any difference whose frame you use, the turning radius on these cars sucks! It is just the nature of the C4 front suspension. Most people that do not modify the quarters or front fenders, use about a 245 tire front and rear, and I have always used a stock 8.5" C5 wheel fitment. If you go wider than 245 on the front, It will start cutting into an already poor turning radius.
Regards, John McGraw
Hello John..
Thanks for the tip. I wasn't really complaining about the turning radius, just curious about it. I am surprised that a wheel with 7" back space would work very well at all.
I have the early C4 chassis with the smallest rotors C4's came with...and have custom 7 inch wide plain steel 15" rims with a 5 " backspace. I have two test tires from Diamondback (wide whites on Michelin 215/70/15's)...I just haven't mounted the wheels or tires yet...been working on other parts of the project.
The wheels and tires I'm rolling the car around the shop on are a little too big I think.. I'm hoping my new wheels and tires will be the optimum combination for maximum turning, daily driving , etc.
I've made my wheel/tire decision...but got curious what others had done. I love the way Billy's cars drive, turn , everything...and drove two of his early on. Bad mistake on my part...LOL! A stock chassis was no longer a consideration for me...then the project took on a life of it's own, which I soon discovered was completely out of my comfort zone in every way. "Everything" had to be just as nice as the chassis at that point....and I wasn't even close on my estimates of the expense it would take to build an early Corvette.
They are similar to nothing else...
Soo...it took way longer than it should..but I'm getting close to the end now...
Thanks...Stan
Thanks...Stan
Refinishing a dash
I'm doing my dash over. The original color was Teal but I'm doing it in black. I used VHT vinyl die on the dash pads and they came out really nice. My question is, should I use the same vinyl die on the center dash unit so that it's a perfect match or should I just spray it with Krylon satin finish paint? I'm not sure if I should use this vinyl paint on a hard fiberglass surface although my dash pads are no longer as soft as they use to be from hardening in the sun. They say this die penetrates the vinyl but it just looks like a flexible paint to me.
Hello John..
Thanks...Stan
Thanks...Stan
Glad to see you getting close the end of your project. We have all experienced that dreaded "job creep", where one thing leads to another and you end up doing far more work than you ever intended.
When somebody asks me about time of budget for building one of these cars, I always tell them to take the amount of money and the time they think it will take, and double both! That way they will not be quite so shocked, when even this does not get the job done!
I don't know if you heard, but Billy Dawson had a pretty big fire down at his place last week, and it did an awful lot of damage. I talked to him a few days ago, and he is still sifting through the remains to see how much stock was lost, but they are on their way to getting back up to speed.
Stan,
OH NO! I hope no one got hurt and everything is ok with Billy and is business. He is currently working on my frame for a delivery date of early October.
I will need to give him a call next week to see hoow he is doing. Not too concern about my frame as I'm for his business.
Yes I did know about the fire John...bum deal. Fortunately a water line going to a large roll around evap cooler was melted and flooded the shop...which helped the fire go out. They didn't even know it had caught on fire and then extinguished itself till the next morning.
I think he said the back end of his Nomad had some paint damage but there was no major structural damage to the building, other cars....or chassis. (His chassis are built in another building Dale...so you are ok!!)
The smoke damage was visible around the out side edges of the shop door when he got there the next morning. I'm sure he went pale when he saw the evidence of smoke and realized something was really amiss.
In fact ...he said when when he realized what had happened he just turned around and went back to his house and sat for a few minutes over a cup of coffee. Took some getting ready to brace himself to go in and see how bad the damage was... Wow!!! I can I relate to that.
Fortunately the flooding reduced the damage...he said it could have been bad much worse. I guess the Lord looks over "good guys" like Billy....a water line melting and flooding the shop floor, what are the chances of that...!!
Stan...
Stan...
Stan,
I still have my 61 Corvette with Billy's chassis and wide white wall tires with 15" custom made steel wheels...but I'm thinking about changing it's look for while.
This thread is forever old but I always loved the red car you had back then with the C5 wheels on it, in fact have it's picture in my saved pictures to this day.
You said you used 245 tires on C5 8.5 inch rims, in this old thread. I'm assuming you used "17inch" x8.5 rims...but could you tell what tire size you used...this thread mentioned 245's but didn't mention the aspect ratio...50, 60's or whatever. Do you recall what the aspect ratio you liked best with the the 17x8.5 C5 rims?
I'm ready for something different (for a while anyway)...and wanted to do what you did on your car back then. I still think that's the prettiest restomod ever...and regret not painting mine red as well.
I think I C5 rims will work on my car even though my chassis used 1985 C4 components which were an inch narrower than the later models if I recall correctly? May need spacers, but maybe not too.... I will to do a test fit once I figure out what size tire you used, unless you happen know the answer to that as well?
Any way hope you get this message and all is well in your world...All the best...Stan Mayfield
I was hoping that pic was in this thread.
You are a whole year older than me, and have more experience, lol. If I still had Windows 98 it might easier...they can't leave anything well enough alone can they. My problem is I do it so seldom that after I learn it. I forget how when I need to do it again ( few years later).
I'm not sure whether Robert was hoping for pics of my car or John McGraw's...
silver837 (03-27-2022)
It has quite a bit more metallic content than stock colors...It is Mercedes Crystal Laurit Silver metallic. The car is totally unstock to include a Corvette Correction chassis and many other mods.
