Where can I find a carb spacer for a '66 L79?
I've read old posts and checked quite a few parts houses including Holley but can't find an insulator/spacer for the 3 hole manifold anywhere. Is it possible to use a 4 hole insulator?
Received 6,943 Likes
2015 C2 of Year Finalist
Why would you need one and if found one wouldn't that cause hood clearance problems
Joking aside, the reason is I think the carb is getting a bit too hot. Car starts, idles and runs strong until I'm in traffic and temp. is over 95. Then the idle will begin to fluctuate and stumble and the motor feels sluggish. I'm only thinking of something about a quarter to a half an inch thick but would use putty to be sure I have enough clearance
I had a 3/4" open spacer on my 66 L79 and had no hood clearance problems with the stock air cleaner when I got the car back in feb. I removed it shortly there after.
That's something else I've been wondering about. Can an open spacer be used on the '66 L79 manifold? Good to know about the clearance. Why did you remove yours?
That's what I was also thinking.
4 holer will work great. i make mine from .2" plywood to extend under the bowls to deflect heat.
open spacers for racing only! can cause stalls on cold starts, poor mpg, etc.
also consider a fuel pump isolator if the problem persists.
a 3-4" fan/duct works wonders. carb loves a cool breeze.
get dryer duct from home depot. 12v fan from old pc.
Did you think it could be something else like your timing or vacumn advance going bad
I was hoping you'd chime in. So, a 4 hole will work. That's what I was wondering.
Thanks, but the car isn't over heating. I think I may have a percolating issue hence the the spacer/insulator.
Matt
Just to be clear. I would use a 3 hole base gasket, 1/4 inch 4 hole spacer/shield, 4 hole gasket, then carb. Is that correct?
Gary
Gary
Kingwoodvette,
I thought about doing that but Matt says 4 holes is ok which kinda makes sense. If I use the proper 3 hole base gasket then a 4 hole plate. Since the carb base is a match to the 4 hole plate there's still a division between the planes.
Hitch
I googled Volley and all I got was volley *****, lol. Can you be more specific?
Hitch
Kingwoodvette,
Hitch
Hitch
Thanks Hitch, it should have registered.
Kingwoodvette
It does make sense when you think about it. The carb base is 4 hole and same configuration as the heat shield, the carb is just a 1/4 inch higher.
Kingwoodvette
