Starter relay
Starter relay
I have a 1960 corvette and am looking for the starter realy, i have power windows and my power window circuit breaker is where most neutral safety switches are located, where would my starter relay be located
Received 2,127 Likes
Somebody will give an answer, but you need a shop manual and maybe some other tech books.
Received 1,126 Likes
GM doesn't use a starter relay like Chrysler and F**d.
There is a starter solenoid mounted on the starter that serves a dual purpose.
It moves the starter drive into engage the flywheel before the starter begins to spin
and then connects the battery to the starter motor.
Jeo
Jeo
where that would normally be there is a power window circuit breaker and it appears to be the original installation, there were not to many cars that were automatics with power windows so still looking for help here
Received 1,283 Likes
Power window relay is mounted on top of the firewall, ABOVE the heater core opening.
Powerglide starter relay is mounted on the firewall close to the transmission tunnel opening.
Do you have an AIM for your car?
Thanks for your help, I did find it.
Received 2,130 Likes
2015 C2 of the Year Finalist
