1964 Sting Ray - Missing Script
I purchased a 64 fuelie a few weeks ago and while walking around Carlisle I noticed I'm missing the Sting Ray script on the back passenger side . I looked and there are no holes where one should have been. Did al C-2 Vetts have that script o the back rear deck ?
St. Jude Donor '10
Yes, it should be there. The holes were probably filled in during a prior repair or repaint. Get a flashlight and check from the underside.
Location: About 1100 miles from where I call home. Blue lives matter.
Received 5,331 Likes
Or the holes can be there but it is very difficult to spot them
On the picture you can see the pattern of the pins that goes thru the body
2023 C1 of the Year Finalist - Modified
2022 C1 of the Year Finalist - Modified
2020 C1 of the Year Finalist - Modified
2019 C1 of Year Finalist (performance mods)
2018 C1 of Year Finalist
Received 6,943 Likes
2015 C2 of Year Finalist
The holes were in the mold for the panel. Hardly any mid years never had some past body work
If you need to drill holes for the emblem i would first buy the emblem, put some ink on the "pins" that goes thru the body and mark it on some hard thin cardboard so you have a template. When you make the template be sure you mark the holes so the emblem will sit straight
Then look at a 1964 that have the emblem in place so you got the correct measurements
Or is there any template to get hold of at any vendors or perhaps any members here have one?
