This post gathers all key A/C discussions into a single easy-to-access list.
It is great if we can keep all threads about factory Air Condition for 1963-1967 Corvette together for easy use for members with factory A/C questions
STV valve operation
http://forums.corvetteforum.com/c1-a...-a-c-cars.html
I did a quick search on some threads and this is what i found about factory A/C:
An A/C Operational Overview
http://forums.corvetteforum.com/c1-a...questions.html
Evacuating, Changing Front Seal, Charging
http://forums.corvetteforum.com/c1-a...placement.html
Cycle of Operations Schematic - 63 Corvette Shop Manual
http://s278.photobucket.com/user/rck...ghres.jpg.html
Outer AC boxes complete and ready
http://forums.corvetteforum.com/c1-a...and-ready.html
Pictures of A/C and insulation of the outer AC box
http://forums.corvetteforum.com/c1-a...e-c2-here.html
Difference on new and old original heather cores
http://forums.corvetteforum.com/c1-a...her-cores.html
A/C question
http://forums.corvetteforum.com/c1-a...-question.html
Air Conditioning Seal Blew
http://forums.corvetteforum.com/c1-a...seal-blew.html
STV valve operation
A/C question
Brian VH McHale (07-22-2019)
A/C is not that complicated if we understand how it works. Evaporation cools things, that is why you get goose Bumps when water evaporates from your skin at the Beach. Compression Heats Molecules of the Compressed Gas as it exchanges to liquid state. (Fluids are virtually uncompressible.) Different components within any system create the optimum results for the greatest cooling effect in the cabin of your car. Unfortunately for us Shade Tree Mechanics specialized equipment prevents us from tackling most A/C related work. Take some time and study your A/C and you'll be able to make good decisions in regards to A/C issue's. A Great online source for learning is the AC Forum. http://www.autoacforum.com/messagevi...&threadid=7102 Search words "Mitch or Big V" are a good place to start. Al W.
This is how i did the insulation in the outer A/C box
I bought the insulation kit from DocRebuild(great product)and also made some more insulation in the evaporator housing myself.
I also used some cement to seal where the insulation pieces meets(so the insulation will not loosen)
Location: About 1100 miles from where I call home. Blue lives matter.
Received 5,323 Likes
Compressor seal replacement:
Thread was formerly a Sticky.
This thread is being unstuck. Please see the link in the Sticky "consolidated" thread:
http://forums.corvetteforum.com/c1-a...ky-thread.html
1966 Air Conditioning Question - R12 to R134
1966 Factory air car with all AC components appearing to be complete. Disassembled all heater and AC components in preparation for conversion to R134. Upon disassembly, STV appears clean, and a new diaphragm has been installed. When reinstalling the STV the Evaporator Oil Bleed line attaches to the STV via a adapter (see photo) which has a schrader air valve!
What is the function of this valve (and the Oil Bleed Line) and does this valve need to be altered for R134?
Is this correct or is something missing?
Also, will my AC pro change the other AC fittings when he charges the system?
Here is a great PDF file about the factory Air Condition provided by forum member Vitaminmopar
C2 FSM Air Condition
https://drive.google.com/file/d/1_Gd...9NXKKzxwT/view
NightshiftHD (07-27-2019)
