C1 watch repair
Old 09-08-2013, 05:28 AM
claudeC1'60
claudeC1'60's Avatar
Default C1 watch repair
Hi all,
I'm trying to refurbish the watch, which is original to the car and dated feb 60, and I can't remove the setting button from its shaft in order to pull out the glass and face.
I made a search, (I promise), but found nothing
Any idea how to do this ?
Thanks, Claude
Old 09-08-2013, 08:04 AM
stratplus
stratplus's Avatar
The **** unscrews off of the shaft.
Try some penetrating oil where the shaft goes into the ****. Hold the shaft with a pair of needle nose pliers and turn the ****. Depending how frozen they are you might need a pair of pliers on the **** and the shaft.
Old 09-08-2013, 01:16 PM
claudeC1'60
Yesss !
It worked, thanks !
Now I have to figure out why the spring keeps on escaping from its hole...and stops the clock.
Old 09-08-2013, 05:32 PM
stafftech
stafftech's Avatar
Going through the same thing at the moment, how did you get the cover off the back?
Old 09-08-2013, 06:38 PM
stafftech
stafftech's Avatar
Ah, I figures it out. Can you show me were the points are for cleaning?
To C1 watch repair
Quick Reply: C1 watch repair
