Hood release cable
Hood release cable
Went into the garage tonight and pulled the hood release handle on my 67 coupe the hood release handle and cable assembly came out in my hand ! i did get the hood open and saw that the cable came out of the brass barrel stop and the bolt that holds the cable secure in the barrel was missing.
so here is my dilemma first the cable is broken (now short)can the cable be replaced?( the one in the hood release handle) or do i need a new assembly - second question,is the barrel stop that is attached to the lever assembly removable - it looks like there is a bolt holding the barrel on to the lever but how do you get to it to remove it to install a new one seems tight
Thanx for any help
Thanx for any help
Thanx for any help
Thanx for any help
Remove the female latch from firewall
Thanx
Will try that but will do a temp repair for now
Went to Ace Hardware and bought a1 ft section of 1/16 inch cable and a
Pkg of aluminum connectors slid the brake handle back into the housing under the dash clamped the new section of cable to the original then clamped the end after I slid it thru the brass barrel ... Good to go works great ... Just waiting till my LIC parts come in for the correct repair
Thanx for the help
Thanx for the help
