removable crossmember in a 66
I have been reading old posts about installing a removable crossmember in my 66. I have tried the phone numbers in those old posts and they have changed. it sounds like putting one in a 66 with a Tremecis possible and helpful. my car is currently in the process of removing the Tremec and it is a bitch with the engine still in. I would like to make the next removal easier by putting in a removable crossmember. any current sources for such a crossmember? any suggestions for making the job easier?things to worry about? Is it easier to do once the tranny is out? possible to do with the tranny in?
Received 1,044 Likes
C2 of Year Finalist (appearance mods) 2019
I found a 69 Automatic cross member for a friend and it was not hard at all. If you can get all the brackets from an original frame you won't need to fab a lot, just some mods to the trans mount. All you need is a sawsall and a mig.
St. Jude Donor '05, '09, '15
I made the center section of the trans cross member removable on the 65 when I put the Richmond trans in. It took some work but glad I did it. I did it with the trans out and the body on.
Tom
Tom
Here's one on Ebay
http://www.ebay.com/itm/68-79-Corvette-Automatic-Transmission-Frame-Crossmember-/331002666295?pt=Motors_Car_Truck_Parts_Accessories&fits=Year%3A1968%7CModel%3ACorvette&hash=item4d114bdd37&vxp=mtr
